586,103 active members*
3,369 visitors online*
IndustryArena Forum > Tools / Tooling Technology > CNC Tooling > Need Floating Tap Holder For CNC Lathe
    Apr 2009
    7
    I am searching for a floating tap holders that can be used in my Century Starn CNC Lathe. I do not have a tool changer on this machine, just a standard 4 post style turret. I have been doing some rigid tapping using the G32 cycle but on larger 5/8 and 3/4 threads the machine gets out of time on the feed out cycle and just stops. I have only heard of these "floating" holder but never actually used one. Any tips on the type to get, place to buy and how to program for them would be much appreciated.
    Nov 2008
    13
    I have used floating holders on older CNC mills but never a lathe. Type I have is a Lindex holder that takes blitz style tap holders. This works quite well. As for programing, most CAM systems will have an option to use a floating holder, they run axis feed a little faster than thread pitch in, then retract faster than pitch to build floating holder tension for exit. This holder has about .5" for insert float and about .75" for exit float. Hope that helps.
  1. Anyone use a floating tap holder for 4-40 in 6061?
    By petriej in forum MetalWork Discussion
    Last Post: 08-05-2009, 11:19 PM
  2. Pulling taps out of floating holder
    By cam1 in forum MetalWork Discussion
    Last Post: 04-02-2008, 05:54 PM
  3. Floating pen holder
    By jrc347 in forum Torchmate
    Last Post: 03-27-2008, 02:27 PM
