586,035 active members*
3,712 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Parameter for using G68 on Fanuc 11M
Results 1 to 13 of 13
    Sep 2009
    4
    I need to rotate a part program 180 degrees but the coordinate rotation parameter is not turned on. Does anybody out there know what parameter it is?? Thanks for your help.
    Jun 2008
    1511
    PM sent.
    Stevo
    Jan 2012
    19
    Re: Parameter for using G68 on Fanuc 11M
    Hi Stev01
    I have the same problem. We have en old Matsuura running a Fanuc 6MB controller. I am machining a curved slot and wanted to use the G68 command to pattern it around a circle. The controller does the first slot but then when it reaches the line:
    G68 X0.0 Y0,0 R45.0
    it gives an error 010
    According to the Programming book this error means that it is an invalid code for this controller, but it describes G68 in the book. Any ideas?
    May 2016
    14
    Use the Plane G17 with this line...it will work..
    Kirit Rupala
    Machine Rebuilding & Sales
    Feb 2006
    1792
    G68 is an option. The book describes everything that is possible to do on the machine.
    Somebody may pm you the option parameter.
    Jan 2012
    19
    Thanks kirit
    ill give that a go
    Jan 2012
    19
    Thanks for the info sinha_nsit
    Quote Originally Posted by stevo1 View Post
    PM sent.
    Stevo
    G'day Stevo1
    I just joined, if this pm was about the parameter for G68, could you please send it to me as well? Much appreciated.
    PM sent.
    Stevo
    Hi stevo, could you me help with the parameter that I need to change to able rotation code please? I really aprecciate your help. Thanks bro
    PM sent.
    Stevo
    I joined this forum because I need help getting tis parameter turned on. PM sent as well!!!
    Apr 2022
    I also need help finding this parameter. Fanuc 10M control.
    - - - Updated - - -
    Dec 2022
    Hi Stevo1
    Jul 2019
    Hi Stevo1
  1. FANUC 6T PARAMETER
    By hiiesalu in forum Fanuc
    Last Post: 01-23-2013, 08:33 AM
  2. parameter 6MB Fanuc!
    By huutanthaco in forum Fanuc
    Last Post: 11-11-2012, 06:06 AM
  3. Need help with Fanuc 6MB parameter
    By nguyenthanhthi in forum Fanuc
    Last Post: 07-24-2008, 05:15 AM
  4. Fanuc 6t parameter #0-5 and #300-304
    By ixoxi999 in forum Fanuc
    Last Post: 12-25-2007, 02:44 AM
  5. Fanuc 0T parameter
    By Master_CNC in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-26-2007, 08:15 PM
