587,043 active members*
3,155 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc
Results 1 to 14 of 14
    Sep 2010
    This is my new build cnc plasma with USBCNC control by USB5-BEding CNC - PC based CNC control
    Attached Thumbnails Attached Thumbnails IMG00272-20111120-1121.jpg   IMG00273-20111120-1121.jpg   IMG00274-20111120-1121.jpg   IMG00275-20111120-1122.jpg
    IMG00276-20111120-1122.jpg   IMG00277-20111120-1122.jpg   IMG00278-20111120-1122.jpg   IMG00279-20111120-1123.jpg
    IMG00280-20111120-1123.jpg   IMG00281-20111120-1126.jpg   IMG00282-20111120-1126.jpg   IMG00283-20111120-1127.jpg
    IMG00284-20111120-1127.jpg   IMG00285-20111120-1127.jpg   IMG00288-20111122-2112.jpg   IMG00289-20111122-2112.jpg
    IMG00290-20111122-2112.jpg   IMG00292-20111122-2113.jpg   IMG00293-20111122-2114.jpg   IMG00294-20111122-2114.jpg
    IMG00295-20111122-2114.jpg   IMG00296-20111122-2114.jpg   IMG00297-20111122-2115.jpg   IMG00298-20111122-2115.jpg
    Sep 2010
    first cutting using oxy/acetylene
    [ame=http://www.youtube.com/watch?v=H_bwKFnCPc4&feature=g-upl&context=G27018a8AUAAAAAAAAAA]VID 00010-20111205-2200.3GP - YouTube[/ame]
    Sep 2010
    i am using usbcnc CPU V5 by edingCNC
    [ame=http://www.youtube.com/watch?v=xAnijgQRgDw]VID 00012-20111205-2222.3GP - YouTube[/ame]
    Mar 2004
    413
    Rex,
    Will you find some time in the near future to give us all a solid viewpoint on the Eding Control ? It is one of the newer USB controls out there and very little forum discussion exists.
    Tell us about the setup,.. tell us if you found any new radical "features" that you have never seen before. Also tell us what other controls you have used in comparison.
    It would be a great help to many.
    Chris L
    Sep 2010
    if you are intended to use this for cnc router, cnc mill and cnc lathe it is a good
    PC-based CNC control systems. But if you want to use this as control for cnc plasma i will not recommend.
    Because in my experience i cannot find a suitable THC in the market that run in this control and his software. The only thing that you can use is Stand Alone THC ( i use the one made by AGELKOM from Turkey ) that's you cannot control in software not like in Mach3. But in all the aspect it is a great product and great technical Support. Also there is another guy in Netherlands (damencnc) has trying to do the THC for this cnc control and i am waiting for it.
    Sep 2010
    Update for my cnc plasma gantry
    a new update for my gantry i just add a spindle in my system
    Attached Thumbnails Attached Thumbnails 20120330_145524.jpg   20120330_150138.jpg
    Sep 2010
    update on my gantry
    [ame=http://www.youtube.com/watch?v=M5zNxsqYViE&context=C495dcc0ADvjVQa1PpcFMGiaEClvFZdYXW-zCtTC8QEGUiUS92dHQ=]CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc Cutting parts 1 - YouTube[/ame]
    [ame=http://www.youtube.com/watch?v=2EqUb6uJGDo&context=C4f18e6aADvjVQa1PpcFMGiaEClvFZddGljYDScGix 3xQqlnmQpyc=]CNC Plasma 10ft. x 6ft. controlled by USBCNC Edingcnc Cutting Part 2 - YouTube[/ame]
    Feb 2010
    331
    how thick was that?
    Sep 2010
    Quote Originally Posted by Zygoat View Post
    how thick was that?
    That is 25mm thick mild steel plate
    Sep 2010
    New update on my gantry
    This my new teknomotor
    My gantry with water pan
    my teknomotor beside my oxygen fuel torch
    Sep 2010
    here is more
    Slave axis ( A axis slave by X axis )
    X axis
    Sep 2010
    more picture
    Sep 2010
    my usbcnc CPU5-B cnc controller
    Sep 2010
    test cut
    [ame=http://www.youtube.com/watch?v=YCnAPU6MG70&context=C4c70b95ADvjVQa1PpcFOjti53JHFkazpZ0MI8bEcX JhOBijMTrWM=]USBCNC CPU5-B by edingcnc - YouTube[/ame]
    [ame=http://www.youtube.com/watch?v=p1UW4cFa9-s&context=C441934aADvjVQa1PpcFOjti53JHFka7Pk5n5Uidbq crkuD_UY46Q=]USBCNC CPU5-B Test Cutting - YouTube[/ame]
  1. Gear Rack Sources-10ft.
    By utahnorton in forum Linear and Rotary Motion
    Last Post: 05-18-2006, 03:39 AM
