586,116 active members*
3,556 visitors online*
IndustryArena Forum > CAM Software > Dolphin CAD/CAM > Missing "Attribute Menu" In Dolphin Partmaster
    Sep 2011
    Running a new Partmaster Vs 10.0.1006 I cannot find the Attribute Menu which is mentioned in the manual. Has anyone else had this problem? Is it a feature of the model or finger troubloe on my part? I would like to use it if possible. Any help welcomed.
    Feb 2007
    414
    Hello,
    Attributes are basically pieces of text added to a drawing which can then modified when the drawing is opened.
    The main use of attributes is to create things like Drawn By: xxxx Date: xxxx etc on a drawing when it is created and opened as a Template.
    Firstly go to Draw > Attributes from the main menu.
    Create the attributes as required.
    Save As.. a Template.
    Open the Template and you will be prompted to change the value of the attribute.
    Open the _default template by using the Icon in the top left corner - it has the down arrow next to the paper icon, you will be prompted with a box where you can change the Value of the attributes.
    Hope this is clear.
    ATB
    Andre
    Sep 2011
    Thank you, Andre for your message. I am working on it, John
  1. Heidenhain "Angle Reference Missing" error
    By Lugy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-13-2017, 06:59 PM
  2. "motor steps per resolution" and "driver microstepping" settings
    By margni74 in forum LinuxCNC (formerly EMC2)
    Last Post: 10-24-2009, 08:33 AM
  3. "J" head type "millport"(tiwan,1980) clutch
    By marksbug in forum Bridgeport / Hardinge Mills
    Last Post: 08-17-2009, 04:48 PM
