586,753 active members*
7,271 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > How to wright comments on a oi-tc
Results 1 to 8 of 8
    Dec 2009
    88
    don't understand out how to add comments in programs on the machine can any one help??
    yama seiki
    fanuc oi-tc
    Sep 2007
    371
    You can use ( ) to write comments...
    GP.
    Jun 2008
    1511
    As GP stated the comments have to go between the () parenthesis. So start typing with a (add comment here) then insert it into the program. The control will ignore anything in (). Depending on your keypad you will have to use the “shift” key to get the characters that you want.
    Stevo
    Jul 2010
    104
    If you do not have the parentheses available as a SHIFT function on your number pad, the may be in the soft key menus. While in edit, press the OPRT soft ket to open the menus. Once open, use the page right soft key to reveal the C-EDT menu. Press that and you will see a few charachters you can choose from, including ( and )
    Dec 2006
    58
    Kev, it could be a parameter setting. it's been 4 years since i checked
    Feb 2006
    1792
    This is the first problem I faced when I started learning macro programming. Square brackets were not coming. Somebody informed that it was a parameter issue.
    Read the attachment for details on how to have both the brackets.
    Attached Files Attached Files
    Apr 2022
    Re: How to wright comments on a oi-tc
    To add comments to a program, you can use the appropriate syntax for the programming language you are working with. In most programming languages, comments are used to explain the purpose of the code, to provide instructions or notes for other programmers who may read the code, or to temporarily disable a line or block of code. C and C++: Use the "//" symbol to start a single-line comment, or use "/* */" to create a block comment that can span multiple lines.
    May 2023
    To add comments in programs on a Yama Seiki machine with a Fanuc Oi-TC control, you can use the parentheses notation to insert comments within the program.
    Remember that the parentheses notation for comments may vary depending on the specific control and programming language used. However, using parentheses is a common way to add comments in Fanuc controls.
  1. 3D CAD Comments
    By jors in forum Uncategorised CAD Discussion
    Last Post: 09-24-2011, 07:28 PM
  2. KX3 anyone got one?? comments
    By ROV CNC in forum Benchtop Machines
    Last Post: 08-03-2009, 07:57 AM
  3. WRIGHT J5
    By hudmut in forum I.C. Engines
    Last Post: 02-12-2009, 09:05 AM
  4. Your comments
    By ESP1 in forum European Club House
    Last Post: 04-03-2007, 06:17 AM
