Machine: 2007 Haas VF2SS
A couple of months back we started to get vibrations problems. So we had a Haas engineer come out a few times, not massive vibration but enough to make the job look bad. They did some testing includign a vibration tester which the results then got posted to the USA. Turned out it was either SPINDLE, SPINDLE MOTOR, BALL SCREW. So we paid upfront for all these three parts and then which ever we didnt use we'd send back for a refund.
We had the spindle changed and this did make the finish better, but from memory when cutting it doesnt sound quite the same, so since we had a motor sitting here we asked the engineer to change that, that made no difference other than being slightly quieter (when all the guards were off). We then had our old one put back.
So we and haas UK are at a point where we/they dont know whats causing the surface finish problems.
We have bought a brand new 50mm tip cutter as our old one had a small mark on it. No difference though. As you can see from the pictures the finish is dull, and has cross'-hatching, and the 10mm endmill used to do the pocket is terrible.
What do you think the cause is, bearing in mind the things we have had changed/tried? The finish used to be perfect and the surface finishing was mirror like.
This is showing the only surface left from a 1mm pass using a 50mm/4tip alum face mill
This is going diagonal X/Y - finish isnt as good
This is purely X axis travel and the finish is good
John
