586,106 active members*
3,267 visitors online*
    Aug 2009
    Need a better finish.
    Hello all,
    First post here - I stop in on occasion to find new ideas.
    I'm a mould maker in southern Ontario for a small shop, currently programming, setting up and operating CNC machines.
    My finishing machine is a Kitamura Mycenter 3xG with a 15000k spindle. I use Cimatron E 9.0 for all of my programs. We are not a production shop, focusing primarily on prototype tooling, low and high volume quality tooling as well.
    I am looking for ideas on how to achieve a better finish coming down steep walls. 1-3 degree draft angles... Currently we will rough and semi finish, followed by a finishing operation.
    IN this case we are discussing a hardened block of H13 50 -52 HRC. Something like a .5" or diameter solid carbide coated endmill (IMCO) with a
    .03" corner rad. I will profile top to bottom at around 2200 RPM (300 SFM) and a feed rate of aprox. 35 -40 IPM. Axial DOC will be around.005"-.007" and radially leave around .003" - .005" stock for finishing.
    I am not happy with the finish and would like to eliminate as much hand polishing as possible. The finish would be suitable for most needs, such as standard shutoffs, and I can achieve great surface finishes on this machine with ballnose endmills. Our tool holders are high quality with excellent TIR.
    Any suggestions on new tooling, machining strategies, feeds or speeds that would improve surface finish on near vertical walls?
    Jan 2011
    id slow the cutting feed after its roughed and climb mill it to <.001 over your wanted size. then do a sweep along skimming the last bit with it climbing an take the whole surface in a few passes .
    i dont realy know alot about the steel you're useing , but thats what i do for some of my stuff . if it works it works if not .......
    Aug 2009
    Thanks for the reply.
    Due the the steep nature of the angled face, I would not be able to take a few passes sweeping along the face. You need all those shallow incrememnts so you can accurately represent the 3 degree tapered wall. What you explained is a great way to finish vertical walls, but would leave my situation a mess.
  1. Problem with side finish (bottom finish is great)
    By tikka308 in forum Tormach Personal CNC Mill
    Last Post: 11-19-2010, 03:40 PM
  2. 8 finish in an ID
    By race8082 in forum MetalWork Discussion
    Last Post: 08-08-2009, 04:22 PM
  3. Zinc-Plated Finish vs plain finish for threaded rod?
    By Almaz in forum DIY CNC Router Table Machines
    Last Post: 10-21-2008, 08:39 PM
  4. Finish on M2
    By yoopertool in forum Mass finishing equipment/media/strategies
    Last Post: 03-26-2008, 12:43 PM
  5. Finish Cut How too ???
    By Biggermens in forum BobCad-Cam
    Last Post: 05-01-2007, 01:59 AM
