Is this thing for real?!
Machine drills square holes in metal.
Too Cool! :cheers:
Too Cool! :cheers:
My Build: http://www.cnczone.com/forums/diy-cnc_router_table_machines/113711-my_build_-_many_thanks.html
Ofcourse its for real, its something close to a rotory broach but a differenet way of doing it.
In the slow motion vids you can see the action it uses to accomplish the task. Pretty cool really and I am not 100% sure how they get it to do like that but its clear to see its doing it.
Whats odd it appears its more than just a new tool, like somehow part of the action is built into the spindle thats running it. I guess we will see more of it in time if it proves to hold up & be cost effective.
Jess
GOD Bless, and prayers for all.
The operating principle has been known for years and I guess I saw my first example at least thirty years ago. The hole is not perfectly square there are small radii in the corners.
that reminds me of how a rotatory engines rotor wobbles as it's running
This type of thing has been around for quit a while. If i remember correctly it involves two slotted plates mounted horizontally together on a spindle or arbor in a manner that allows the two plates to move in a manner allowing the the cutting tool to move in the way as seen in the video. Each plate has two slots that are parallel and set towards the outer edge and the plates are mounted at 90 degrees to one another. This type of thing was normally mounted in a drill press and was quite common in work shops.
Drilling non-round holes is easy!
I can drill triangular holes with an ordinary twist drill ...
Cheers
PS: it's actually just about the same technique too !
