1) Processing size(L*W): 1200mm*2400mm
2) Spindle rotate speed: 8000~24000r/min
3) Power Supply: 3KW
4) Voltage: 220V/50Hz, 380V/50Hz (Adjustable)
5) Control Accuracy: 0.01mm
6) Processing Accuracy: 0.1mm
7) Dedicated software: ARTCUT, TYPE 3, etc.
8) Imported double nut ball screws and high accuracy guide rail
9) High power and variable frequency Spindle
10) Cutter size: φ 3.175/4/6mm (Adjustable)
11) Order format: HPLG3DG-code
12) CNC stepping and AC servo
13) Circulatory water-cooling
14) Working environment: Temperature 0~40 ℃
Humidity 37%~75% (RH)
15) Z Axis stroke: 120mm
Waterjet Cutting Machine,China Waterjet Cutting Machine,Nanjing Jete Digital-Control Machinery
