586,102 active members*
2,947 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > All the CNC parts for G0704
Results 1 to 14 of 14
    Nov 2011
    19
    Would someone be kind to list all the pieces and kits I need to convert the G0704 to CNC? I have a good computer.
    Seen these so far, anything else?
    http://www.ebay.ca/itm/280778984342?...84.m1438.l2649
    NEMA 23 CNC Router Stepper Motor kit
    CNC Software
    Jun 2005
    53
    I would recommend the dmm servo kit as they are a local company. I can make the motor mount plates for you if you are interested.
    Nov 2009
    4415
    Have you read Hoss' thread?
    Oct 2010
    266
    you would also need the ballscrews and nuts, the mounts for all three nuts, motor to screw couplers, wiring.
    Nov 2011
    Quote Originally Posted by sdubfid View Post
    I am interested in some simple bracketing for my stepper's :banana:
    would you be willing to ship to the us?..
    please pm me
    Nov 2011
    19
    Quote Originally Posted by Fastest1 View Post
    I'm new here so I don't much know anything of these forums, but I shall. I've only used a small manual mill and know just enough to be dangerous. I bought this after reading how successful the mill has been for people.
    I don't want to mess around with partial kits and such, the more complete I can buy the components is best.
    Nov 2011
    19
    Looking at the parts PDF (#246-2 retainer cup) has a nasty wobble. I'm thinking this is not a good thing as it sits on the top of the drawbar. I've not even cut anything yet.
    Oct 2010
    266
    Quote Originally Posted by ALO View Post
    I saw that also when I first started mine and thought there was something wrong. Don't worry bout it though it isn't because your spindle is messed up
    Those have very fine threads, it's possible they crossthreaded it during assembly.
    Unscrew it, and check it out, one was sent recently with the threads miscut.
    I tossed mine early on and went with a standard bolt and made a spanner.
    Projects2
    and then this.
    Projects2
    Hoss
    http://www.hossmachine.info - Gosh, you've... really got some nice toys here. - Roy Batty -- http://www.g0704.com - http://www.bf20.com - http://www.g0602.com
    Nov 2011
    19
    motors
    1: CNC 3 Axis Stepper Motor Kit with 570 oz-in motor and KL-6852
    Bipolar Driver with 48V/12.5A Power Supply (110V/220VAC):$543
    (3) 570 oz-in stepping motors, NEMA 23
    (3) Drivers (5.2Amp 24-68 Volts, 1-1/256 microstepping)
    (1) 48VDC /12 .5A Power Supply 110VAC/220VAC
    (1) Breakout board
    (1) 5V power supply
    Any reason this wouldn't be good enough?
    Nov 2011
    19
    maybe this
    5: CNC 3 Axis Stepper Motor Kit with Digital stepper Driver for BF20,
    Grizzly 0704, Busy Bee CT129, PM-20 WMD30 king KC-20VS, Weiss
    WMD20LV (110V/220VAC) $647
    (1) 906 oz-in NEMA 34 Stepper Motor
    (2) 570 oz-in stepping motors, NEMA23
    (3) Digital Drivers (5.6Amp 24-50 Volts, 1-1/256 microstepping)
    (1) Breakout board
    (1) 5V power supply
    Any advantage to the nema34 on the Z mount?
    Feb 2010
    114
    Must be a QA or person with no sleep on the assembly line. I have the wobble as well.
    Sorry about the rotation of the video, I was on my phone and it auto rotates for me.
    Here's a video of mine.
    [ame=http://www.youtube.com/watch?v=QEwBSbr0vTY]Grizzly G0704 - YouTube[/ame]
    The cap mentioned previously does unscrew. (Just use the larger wrench included and also that new spindle pin to hold the spindle if you want).
    Question, which part is cross threaded the retainer cup's threading or the spindle part #246V2
    Wobble is nothing unusual from machines like this that have long narrow unsupported upper spindles, many machines will experience some wobble.
    The spindle nose is where it counts.
    You no doubt could move the top back and forth with your fingers.
    If it vibrates too much at speed, remove the retainer, inspect and carefully reinstall so not to crossthread.
    I'd just toss it like many of us have especially since you have the spindle wrench now.
    Hoss
    Nov 2011
    19
    wobble
    That is exactly what I was refering too. :banana: I suppose it's the same for all.
  1. No Joy with my New G0704
    By DogWood in forum Benchtop Machines
    Last Post: 07-05-2016, 05:49 PM
  2. G0704 CNC Plans
    By mrcodewiz in forum Benchtop Machines
    Last Post: 02-23-2016, 02:09 AM
  3. RFQ A few parts from Hoss G0704 Plans
    By LLDesigns in forum RFQ (Request for Quote)
    Last Post: 10-21-2011, 09:13 PM
  4. Parts list & Basic Tooling for G0704 Conversion?
    By j.steensen in forum Benchtop Machines
    Last Post: 07-29-2011, 05:32 AM
  5. G0704 or a X-3
    By USN in forum Benchtop Machines
    Last Post: 05-30-2011, 08:24 AM
