Let's say I create a part in Mastercam...ie create the geometry in CAD then the associated tool operations to cut/dril it out..
Can this part then be panelised .....ie more copies of the part on the same stock, but copied along with the toolpaths created for the original part?(else that's a lot of work then having to add all the toolpaths on the copied gemetry!)
if so, how is it done in practise? (or do folks just use a G-code offset to produce the same part over & over on the same stock?
