586,341 active members*
3,344 visitors online*
Page 1 of 2 12
Results 1 to 20 of 21
    Jul 2008
    27
    Unhappy Bridgeport CNC Series II Boss 6 is Dead!
    Powered up my Bridgeport CNC Series II Boss 6 after a peroid of being idle. Unit failed with the following symptons:
    At power up the console readout display flashes 000 60007 then goes blank. The Run, Goto, and Hold LED's are steady for about 3 seconds and then extinguish followed by illumination of the ABS LED. The limit switch is illuminated but can be cancelled. Upon cancelling of the limit switch and a reset (tape drive cabinet) the spindle can be started. The only other item that does anything is the edit button can be pushed resulting in the Run LED illuminating. The Hold button will also illuminate the Run LED. Once the Run LED is illuminated it will extinguish after about 15 seconds. No other functions appear to work.
    Things we have tried:
    Removed and cleaned all PC boards using contact cleaner, soft toothbrush and low pressure compressed air. Used an eraser to clean the backplain contacts. Adjusted the voltages (small blue and violet wires above power module) to 05.00, 12.00, -12.00 VDC. All voltages are steady and do not change any when power is applies to the spindle.
    Checked both regulated and unregulated voltages and nothing appears to be outside the norm.
    Any help would be appreciated!
    Wayne
    Nov 2004
    3028
    I would be looking at replacing the LSI-11 board (KD11L module by Digital Equipment Corp.).
    George
    Jul 2008
    27
    Wink Bridgeport Series II Boss 5 Need Help
    George,
    Thanks for your quick reply! One thing I forgot to say is that the stepper motors are locked when power is on. When you try and move them you can feel electronic resistance (slight vibration or hum). Would this indicate that the stepper motor controls are working as advertised? Do you have a source for the Processor LSI 11 that you recommend?
    Wayne
    Jul 2008
    27
    George,
    Do you know someone that has and wants to sell an LSI-11 board?
    Wayne
    grigsbyatwowwaydotcom
    Nov 2004
    3028
    Stepping motors are interesting. Even when off, if turned by hand you feel the poles of the motor, like a growl. A old motor has less growl because the magnetic fields have decayed. When power is applied, it does hold the rotor strongly but can be overcome. Any resistance to the motor turning (keeping up with commands from the control) will result in the rotor being attracted to the trailing pole instead of the leading pole. You then hear a whine as the motor oscillates between poles. The same occurs if a output transistor is shorted.
    I do not know of any LSI-11 boards that are available. Years ago I did a Google search of it and found a lot of data about it but I have doubts that any repair parts are still available.
    You may be forced to consider a retrofit.
    George
    Jul 2008
    27
    Unhappy Boss 5 vs Boss 6
    Can anyone advise me if the LSI 11 processor board is the same in a Boss 5 and Boss 6?
    Wayne
    Nov 2004
    3028
    Yes, they are the same.
    The BOSS4 and earlier had a KD11-F module. This had 4 LSI integrated circuits.
    THE BOSS 6.1 and BOSS 7 had half size LSI-11 boards.
    George
    Jul 2008
    27
    Boss 5 vs Boss 6
    Just to be clear, if we find a board that has 5 of the large Digital IC's like the one pictured below it should work.
    Sep 2011
    31
    I have an LSI 11 from a Boss 5. It was working before I started retrofitting the control.
    Jul 2008
    390
    Quote Originally Posted by grigsby View Post
    Have you tried baking the board to reflow the solder? I would try that if I were you. Just don't bake too long. Also, I wouldn't bake the board if it has DIP components on both sides or you'll only have half of your board.
    Jul 2008
    27
    Cool PDP 11 Board
    Quote Originally Posted by scottly View Post
    How much do you want for your board?
    Sep 2011
    31
    I don't know what a fair price is for the board? You may want to try reseating the 5 big chips in their sockets first. Here is a pic of my board:
    Jul 2008
    27
    Smile PDP 11 Board
    Yes, I have removed the five big IC's and reseated them. I first tried pushing them in securely, all to no avail.
    Wayne
    Jul 2008
    27
    grigsby
    George,
    Is the LSI-11 #19273222 boss 5 on type 1 and type 2 interchangable?
    type 1 boss 5 into type 2 boss 6?
    Wayne
    Jul 2008
    27
    boss 4-5-6
    George,
    My buddy has a boss 4 that does not run.
    Do you think if I put a full set of boss 6 cards out of my machine
    in his boss 4 it would work?
    That is if boss 4 is wired inside machine same as boss 6. ???
    His machine is setting in wharehouse and not wired to mains so I can't try it.
    What would it hurt to try it?
    I have a lot to learn. ;<(
    Grigsby
    Nov 2004
    3028
    NO!!!
    Totally different set of boards.
    XDI vs ZDI, RCK vs ZCK, NTP, ERS is different.
    George
    Jul 2008
    27
    George,
    I understand not to mix them.
    Do you understand putting in a full set?
    Are the internal wiring same? or diff?
    What would it take to get a boss 4 to run with a set of boss 6?
    Can I change internal wires to boss 6?
    Are acc same?
    Are smd same?
    What is the same?
    Thank you
    I am having better luck finding boss 6 but boss 4 is harder to find.
    I hate to give up on a machine.
    grigsby
    Nov 2004
    3028
    Card cage is wired differently.
    George
    May 2016
    5
    Re: Bridgeport CNC Series II Boss 6 is Dead!
    I don't know if anyone is still following this thread, but I had the same problem, a 60006 or 60007 message at power up. Cleaned all the boards and reinstalled them. Now it powers up, but the readout is now completely blank. In other words, I seem to have made the problem worse. Can anyone tell me what these boards do? LSI-11, XDI, RCK, and ERS? Those were the boards I cleaned with electronic spray cleaner, a brush, and dawn detergent & water. There is an empty slot that says IBX. What Boss series do I have?
    Nov 2004
    3028
    If you have no display, I would check the output of the logic power supply. Also make sure all boards are seated correctly and facing in the same direction.
    The display board is very static sensitive but if you did not remove it, either is is a power issue or signal issue.
    George
Page 1 of 2 12
  1. Series 1 BOSS 5 X Axis Dead, still dead after new transistors
    By keebler303 in forum Bridgeport / Hardinge Mills
    Last Post: 02-01-2014, 04:27 PM
  2. Bridgeport Boss 6 Series II
    By grigsby in forum Bridgeport / Hardinge Mills
    Last Post: 09-29-2012, 03:37 AM
  3. Bridgeport Series 1 cnc Boss 5
    By pyroboby in forum Bridgeport / Hardinge Mills
    Last Post: 09-01-2012, 11:44 PM
  4. Series I Boss 5, All axis dead
    By timprebleco in forum Bridgeport / Hardinge Mills
    Last Post: 01-31-2009, 06:49 PM
  5. Bridgeport Series I Boss 4
    By millwrightguy in forum Bridgeport / Hardinge Mills
    Last Post: 06-28-2007, 02:07 AM
