586,277 active members*
3,572 visitors online*
Results 1 to 16 of 16
    Oct 2007
    106
    M01 Optional Stop not working
    I have this problem in a Yang Lathe with a Fanuc O control,
    the M01 optional stop is not working.
    It only works if I program it directly after a M00, like this:
    T0100
    G97 S300 M3
    M0
    M1
    M1
    M1
    M8
    M30
    If I remove the M00 the program ignores all the M1 and jumps directly to the M8.
    Sep 2010
    1230
    Quote Originally Posted by erd39030 View Post
    T0100
    G97 S300 M3
    M0
    M1
    M1
    M1
    M8
    M30
    In the above case the M0 is halting the program. Are you saying that with the M0 programmed, the program then halts again at each and every M1 that follows, and that without the M0 all M1s are ignored when the Optional Stop switch is set to On?
    Regards,
    Bill
    Oct 2009
    297
    Look for an optional stop button in the MDI panel. M01 is programmed in the ladder.
    First off i am assuming the OPTIONAL STOP button is pressed?
    Check to see what the X input address of the button and F154#6 are doing. It looks like your problem is in this area.
    CNC Data Ltd
    www.cncdata.co.uk
    Oct 2007
    106
    Thanks for your help
    Thank you guys, for your fast response.
    Yes, the Optional Stop button is pressed (and iluminated too)
    Bill, that's right, the program stops at M00, then I must press Cycle Start at each M01.
    If I remove the M00 then the program ignores all the M01.
    Look at this program:
    M00
    M01
    M01
    M03
    M01
    M01
    M30
    The program halts at M00 and the following two M01, then starts the spindle and ignores the rest M01.
    CNC Data,
    the maintenance manual (B-62545EN/02) says that the signal are F154.6 for M01, and F154.7 for M00, but neither one appears on the ladder.
    When I press the Optional Stop button, then the line S075 iluminates complete.
    The line S076 does not close. The contact M01 (R602.7) closes only if I let the cycle start button pressed by several seconds.
    Is anywhere a parameter or a timer for the cycle start button?
    Thanks for all your help:
    Everardo.
    Attached Files Attached Files
    Jun 2007
    119
    which element is not iluminate in line S076 (X8.6; R602.7; X0.5; F149.1)
    What is X0.5
    Oct 2007
    106
    The R602.7 and X0.5 are remain off.
    The X0.5 is the Cycle Start button. If I push it for some seconds, then the control recognizes the M01,
    as if the ladder ran trough the S076 line before the signal R602.7 from line S074 had time to arrive.
    Jun 2007
    119
    I think the problem is X0.5 , maybe is remain blocked
    check in diagnostig page for x0.5 it should be 0
    Oct 2009
    297
    Could be the cycle start button has a problem, but just check if you mistakenly activated the single block button (SBK).
    Oct 2007
    106
    Red face
    Well, I am sure that it is not the Single Block.
    And I am not so sure about how to find the diagnostic related to the X0.5.
    I didn't had time today, but tomorrow I am going to dismount the panel and look how it is connected the Cycle Start button. I noticed that the button is not lighting, probably the lamp is burnt out. Could that cause a problem?
    Anyway, thanks everybody for helping me. I will keep you informed.
    I am also working in three other "projects": Trying to resucitate a 1990 Haas VF-1 that freezes with no alarms, an old chucker lathe with damaged dc drives and attempting to use a renishaw probe in a Yang mill with O-MD control.
    Surely I will learn something, someday, somehow, out of this. :idea:
    Everardo
    Oct 2009
    297
    Everardo
    Pushing the parameter button twice takes you to the diagnostics screen. Diagnostics will be shown in the upper left of the screen. Look at the diag x0 and it says bit #5. For example X0 = 00100000 in this case bit #5 would contain a ONE.
    Oct 2007
    106
    Cool Ohh!
    Mmmm... So X0.5 is related to Diagnostic 0 bit 5 :-)
    Now it makes sense.
    I was completely lost looking at diagnostic 5.
    Does the same applies to all signals (R,G,S,F,X,Y)? Or only to X & Y signals.
    Well, signal X0.5 is set to 1, and changes to 0 while I push the cycle start button. Does it means that the pushbutton is inverted? That it should be a NO instead of NC?
    Thanks so much:
    Everardo:cheers:
    Oct 2009
    297
    When pushing the cyclestart button you should see a one in diag. X0.5.
    Regards
    Oct 2007
    106
    Fixed!
    Fixed! :-D
    It was the cycle start push button,
    wired NC instead of NO
    Why? Only god knows!
    Thank you Alex.
    I owe you six tecates. If you are in Ensenada B.C. area,
    you are welcomed to cash them anytime. ;-) :cheers:
    Best wishes to everybody
    Everardo :wee:
    Dec 2008
    28
    Re: M01 Optional Stop not working
    Quote Originally Posted by alexfanuc View Post
    Hi Alex,
    My name is Paul ,i have probably the last working Cadillac NC100 with GN5 control .
    I have taught myself to maintain this unit as it is accurate and i am a small one man shop .
    the only problem i cannot figure out is why the optional stop does not work ,the button is wired and i checked the bulb in the push button switch.
    but it has only one effect on the program ,when i put M01 in the program it will freeze at that line with the cycle start lamp lit.
    pushing reset turns off the lamp
    but it freezes with the m01 switch on or off
    m00 works as intended as does m02 and m30
    any thoughts
    Thank you
    Paul
    Dec 2008
    28
    GN5 has address buttons that allow me to see parameters and diagnostic inputs and outputs .
    None of my manuals list a parameter or diagnostic input -output for an M01.
    I don't have the original lathe manual,just the control manuals,
    I carefully watched the relays at the bottom of the cabinet trying to discern which may have to do with
    the M01 function
    I run a short program including the M01 and relays come on when it gets to the M01 line but just freezes.
    apologies if I am not explaining this well enough, I am hoping you can guide me to some way to solve this.
    I will double check all inputs and outputs to see if i get any action when pushing the M01 button.
    Peace
    Paul
  1. Optional Stop will not disengage!
    By jupiteral in forum Fadal
    Last Post: 05-23-2014, 06:54 PM
  2. Wasino VMC-18 Fanuc 6m, optional stop
    By GTMondock in forum Fanuc
    Last Post: 01-23-2013, 08:38 PM
  3. NV5000 optional stop does not work
    By teal854t in forum Mori Seiki Mills
    Last Post: 05-27-2012, 05:19 AM
  4. How to activate the optional stop
    By dingo0722 in forum Haas Mills
    Last Post: 01-25-2011, 04:16 PM
  5. Mo1 Optional Stop
    By a1moldmaker in forum Fadal
    Last Post: 04-09-2007, 03:08 PM
