586,121 active members*
3,005 visitors online*
    Sep 2009
    27
    Inverter Keypad Help
    Hiya All,
    Got an excitech for a few months now, still quite green in the cnc world.
    For a while now I'm using the Inverter Keypad's "up and down arrows" to set the Spindle speed.
    Now my question is, can I set up the Inverter Keypad so I can adjust the spindle speed with the "knob" on the left hand side from the "up" botton?
    If so how do you do it, been looking around for a few weeks but can't find it.
    Cheers,
    JLD
    Hello,
    I don't believe that you can , what inverter is connected to the other end of the key pad. If you have the model of it the instruction manual or so info might be available on here or the web.
    The chinese inverters have some limitations. Take a picture off it and let's see if we can find the manual.
    Jon
  1. Using the dot key of the Numeric keypad - PLEASE HELP
    By nmg.mendes in forum Uncategorised CAM Discussion
    Last Post: 06-18-2009, 10:17 PM
  2. Experimental Keypad - WIP
    By skiddaw in forum CNC Machine Related Electronics
    Last Post: 03-16-2009, 02:51 AM
  3. Keypad as Pendant?
    By SPEEDRE in forum Mach Software (ArtSoft software)
    Last Post: 03-31-2008, 04:59 PM
  4. Can't use keypad arrows
    By bcnc in forum Mach Mill
    Last Post: 10-25-2007, 01:28 AM
  5. Keypad blues
    By Sprew in forum Haas Mills
    Last Post: 07-01-2006, 06:40 AM
