I started using a Bosch Colt as a spindle router a while back. The first couple I got quite good life out of running 750 and 900 hours respectively. I would check the brushes and replace them as needed, but the bearings did quite well. I would see finish issues before they would start to get so hot that they would damaged anything. I figured I would just replace bearings every 500 hours and not worry about. No such luck. The newer ones started failing catstrophically at only 200 or 300 hours. One at only about 150. The difference in finish and bearing over heat would occur quite close together and melt the nylon insert in the router before I could stop the machine and replace the bearings. Once that's melted its quite difficult to dissassemble the router so I just have to replace it. I've gone through more than a couple of Bosch Colt Router. I think I have five of them on the bone pile right now.
Anyway. I have decided the Bosch Colt is not up to the agressive cutting I am doing, and I am ready to look at something better. I don't really need more power because I am working with cutters from .0625 to .125 most of the time, but I am pushing the maximum load on the cutters. I guess what I need is a spindle that can turn fast like that and hold up to the side load on the bearings as it cuts. (I do bog the motor once in a while on a plunge cut)
I'm not against buying one of the Chinese import VFD controlled spindles. I already have a 220V circuit on that wall I could use. I could get by with only the 24000 max RPM they advertise, but I don't want to spend several times what a wood regular wood routers costs if they won't hold up any longer running at their max speed.
On an aside from that. Are there any regular wood routers out there in similar size and spindle class that would make a better quality longer lasting replacement for the Bosch Colt. Slightly bigger would be ok but like I said I don't "need" more horsepower.
One of the issues I think with the Bosch Colt by the way is that the front main bearing is "insultated" by the nylon bushing it presses into. If it were pressed into an aluminum bushing it would transfer heat away from the bearing better and it would loose tolerance before it overheated more consistently. I had considered making my own bushing, but then the cost in time over weighs the savings in the router. This leads me towards looking at one of the import water cooled spindles. The back bearing has no more play in it then a new one when the front bearing fails. So its obviously the side load from milling that causes it to fail and heat up.
All of that not withstanding I also considered making my own spindles and using an external motor of some kind, but the array of available bearings is dizzying and I wouldn't have a clue where to start to select an strong high speed bearing for the application.
Summary:
Import 3 Phase VFD controlled spindle - Life under load with aggressive cutting?
Off the shelf router as spindle - something substantially better than the Bosch Colt?
I can make my own mounts anyway I go.
