586,051 active members*
3,590 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Ultimax replacement graphics screen
Page 2 of 2 12
Results 21 to 26 of 26
  1. #21
    Aug 2012
    31
    Re: Ultimax replacement graphics screen
    [Hi fantastic job i tried the same using 12v screens it was hopless !! could you please give me the info id love to change it to set up, it would be nice to be able to read them clearly !! also where you bought your screens from
    Many thanks in advance
    Adrian
  2. #22
    Sep 2003
    174
    Ok you need to read the whole thread on this as it turns out not all these machines are the same. The early one are quite a bit different, ultimax 2 etc. My mil is ultimax 3 version 1 so I can only say what I did and it worked for me.
    First I plugged an ordinary pc monitor into the pin outs on the circuit board on the back of the CRT, sat it on a table and plugged into the wall for power. This was to test the signal to the monitors was good as the graphics cards can be a problem sometimes. I had to modify the panel that covers the monitors and make some brackets to hold the new ones in place. All the photos are on here. I used a multimeter on the pin outs on the CRT board to see which wires go to which connector for the VGA plug, made a diagram then snipped off the old connector and soldered on the new VGA plug. It was very tricky but I managed it, just be careful and make sure you are confident you have it correct. Can't go back once the connector's snipped off the wires.
    For the power supply, on the PCB under the front panel there was a block connector to the right and a choice of 12v and 24v. I used a small screwdriver to push the wire out of the 24v slot and put it back in the 12v slot.
    I got the monitors from these people:
    Lilliput Europe
    I hope this helps and please understand this is something that I did to my own machine and it worked ok but was difficult. Your machine may well be configured different. It all depends on the year of manufacture I think.
    Best of luck.
  3. #23
    I have this Hurco Km3p with UltimaxII .After the startup right side Graphic Crt is not working Is there any way to start it up Also the Keys are not operating
    Attached Thumbnails Attached Thumbnails IMG-20210124-WA0003.jpg   IMG-20210124-WA0004.jpg
  4. #24
    Aug 2009
    1573
    Quote Originally Posted by Sehjot_Singh View Post
    ... dead Battery most likely started the problem. Read the Thread below may help.
    https://www.cnczone.com/forums/hurco...-software.html
  5. #25
    Quote Originally Posted by machinehop5 View Post
    Can u guide me if possible as that thread is of another machine. Which battrries i need to replace
  6. #26
    Apr 2023
    I liked Lilliput monitors, I recommend them for use
    https://lilliput.net/
Page 2 of 2 12
  1. Ultimax !! Text Screen Problem
    By Rich Carlstedt in forum HURCO
    Last Post: 10-02-2013, 06:13 PM
  2. Why is the graphics screen doing this? KM3P Ultimax II
    By pondringjunkman in forum HURCO
    Last Post: 12-23-2012, 01:01 PM
  3. Replies: 4
    Last Post: 07-11-2011, 01:07 AM
  4. Replies: 4
    Last Post: 06-13-2010, 11:28 PM
  5. 2412 graphics screen
    By Larry Myers in forum Sharp CNC
    Last Post: 03-12-2008, 01:36 AM
