586,108 active members*
3,293 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Rotational axis (a) feedrates REALLY SLOW!
Results 1 to 8 of 8
    Feb 2008
    31
    How can I normalize the feedrates for the 4th axis with those of the the x,y,z axis? I'm thinking I'll have to either change the post processor or run a script on the G code afterwards to do some feedrate translations based on the A axis rotational method (degrees vs. inch movements)
    It's called Inverse Time Feedrate Coding. G93.
    There's a G code for ITF instead of Feed Per Minute (G94), and the F word is the inverse of minutes it takes to complete the move.
    For example G93 F2.0 will take 1/2 minute to complete the move.
    F needs to be in every move.
    What control are you using?
    Feb 2008
    31
    Using Mach3 for controller SW.
    I've just been adjusting the overall % feedrate offset downward until my other axis don't "trip" from being "rapid-ed" to quickly.
    I'd like to solve the problem instead of bandaiding it and get to work.
    I don't have mach3 here, so I'm going from memory.
    There's a checkbox in Config >Toolpath, and you need to enter the radius on the settings page.
    Note that the value entered for radius is from the center of rotation to Z zero. If you zero your Z on the surface of the cylinder, then enter the radius. If Z zero is center of the cylinder, then enter .001 for the radius.
    This should get your feedrates working properly.
    Feb 2008
    31
    I knew about the radius entry on the settings page, but will have to look at the other Config/Toolpath item. Any details would be great!
    Something like use feedrate for rotary axis. Should be self explanatory, on the right side near the top.
    Dec 2008
    4548
    It's a Mach3 setup thing... Go here and search for it in their forum and read a couple reply's....
    ArtSoft USA - Home of Mach3 and LazyCam
  1. Nakamura C-Axis Feedrates...
    By MaCroB in forum Uncategorised MetalWorking Machines
    Last Post: 05-11-2019, 05:52 AM
  2. 4 axis rotational cutting problem
    By kilrabit in forum MadCAM
    Last Post: 11-30-2010, 02:26 AM
  3. 4th Axis very slow
    By irv in forum Syil Products
    Last Post: 12-14-2009, 07:30 PM
  4. Vacuum hold-downs and rotational problem about the z axis
    By cpcp in forum Work Fixtures / Hold-Down Solutions
    Last Post: 12-08-2006, 02:02 PM
  5. home switch for rotational axis
    By xyz100 in forum DIY CNC Router Table Machines
    Last Post: 07-31-2006, 07:14 PM
