587,501 active members*
2,778 visitors online*
Results 1 to 6 of 6
    Dec 2011
    2dn LS overtravel
    Hi there.
    I have a problem with my Kitamura mycenter 1 with Fanuc control. I was checking the limit switches and touched one of them with a piece of metal and it activated, now I have an alarm 1011 overtravel (2d LS). I cant move any of the axes and neither get rid off the this alarm.
    Feb 2012
    Im told that holding the 2nd ls switch overides the overlimit but it dosent work for me..... I manually turn the screw untill its off the switch and then re start the machine Ive done this several times with our kitamura mycenter1
    if the machine is not in overtravel and you acttivated the switch and it wont come out of lock even if you restart the switch is probably stuck so take the switch apart and find the problem
    take care
    JAK
    Jan 2011
    I have the Troubleshooting for the Kitamura Mycenter HX400iF,May be the same as your machines. You can reference attachment.
    Attached Files Attached Files
    Aaron
    Nov 2009
    71
    Not sure how much you are familiar with Kitamura's apologies.
    The second limit remove switch should be held on to disable the second limit switch. Set the axis switch and move the axis with the handle be sure to set the increments to X10. Then remove the faulty switch and clean out the plunger. It’s pretty simple I had to clean both the X and Y axis switch on a Mycenter 1
    Dear Friends
    I need Parameter list for Kitamura Mycenter 3 with Fanuc 11m Control
    L. Sakthivel
    Email:[email protected], website:www.premierengrs.com
    Apr 2020
    Quote Originally Posted by Eric MFG View Post
    Not restart
  1. G99 Overtravel
    By deere2210 in forum OneCNC
    Last Post: 12-24-2012, 06:41 PM
  2. Overtravel on G28
    By Dirty25RS in forum Fanuc
    Last Post: 02-17-2012, 09:28 PM
  3. 10T Overtravel
    By grease in forum Fanuc
    Last Post: 10-17-2007, 04:19 PM
  4. Help with Z overtravel
    By mbam in forum Fadal
    Last Post: 04-27-2007, 06:12 PM
