The machine parameters are a file BMDCPRMS.SYS so just use DOS to copy it to a floppy. See if you also have a LEADCOMP.DAT file. Only machines that needed it had it. Again copy that to a floppy.
MAKEDISK should copy the machine software and parameter file to a floppy but will not be bootable and will not install DOS.
Write down your CMOS settings too.
Thank you for your kind words.
Remember that the TC22 uses a oiler with a cam that lifts a plunger and it falls off the cam about every 20 minutes of machine motion, It will take a while to get some UV dye through the system. (never used it). I believe I would be replacing the metering units first and see if there is a difference.
George
