I an having some following error issues with my '92 Partner 4 with Centurion V control. Following error runs exactly the same value plus and minus up to about 70 ipm, then when I step up to 80 ipm, it goes running off in only the minus feed directions, i.e. X minus, Y minus and Z minus... the plus directions all stay around the .050" level while the other direction climbs until it faults out the drive at .250".
We were just working with the balance and signal pots of the Fenner drives and I found out about some set up procedures for the cards, where you check ohms resistance and voltages at certain points, so now I will check all of that first.
That got me to wondering if there was the same sort of procedure for the Acroloop cards, so if anybody knows of a process where I can make sure they are set correctly, I'm all ears.....
Right now the machine is running, but I have to have my rapids set under about 70 ipm and such or the drives fault.
