Lots of sharp guys here so I figured I'd ask...what is the procedure for replacing the X ball screw on a VMC 40? I've got some mechanical noise that that is related to the rotation of the screw. Its worse going in the + direction. It can be felt in the table as well. I also have finish issues when milling angles but thought I would get the mechanical straightened out before I adjusted the clock and gain. We are now checking the bearings on the ends and will replace them as needed.
The coupler shows some wear and will be replaced. It almost feels like there are bad spots on the balls as it sometimes is worse than others. Does anyone have a source for ball screws (part numbers would be great).
Lastly, if anyone can tell me the procedure for ball screw replacement, I would be very appreciative. Thanks in advance
John
