586,121 active members*
3,099 visitors online*
    Dec 2011
    Bridgeport VMC600/22
    Help,
    I have a bridgeport with a Heidenhain TNC 370 controller will
    The SIMODRIVE 611 (6sn1145-1BA01-0BA0) was replaced after a failure.
    Everything seems to work except the toolexchanger, it occurs in the exchange position, only the turret will not turn and gives an error "tool changer not counting".
    Manually the exchanger turn clockwise.
    Manually it will not turn counterclockwise and it gives an error "tool changer not counting".
    Is there anyone who can help me to resolve this error?
    gr Kees
    1121
    sounds unrelated
    toolchanger is a geneva gear so IIRC there is a sensor that sees every time the mechanism turns[one tool pocket]
    perhaps this sensor is NFG
    Dec 2011
    hello Gus,
    all 4 initiators works. The initiators of the toolchanger, 1x and 1x neutral position change, detecting the position of the arm. the initiator of the toolchanger detects every pocket and the other detects the the 1st position of the turret.
    gr. Kees
    Oct 2008
    44
    If you can turn it manually clockwise, check whether the counter sensor is going ON/OFF when the magazine turns, by examining the top indicator light. When the magazine stops rotating, sensor should be at the ON state.
    I encountered situation where the gear is somehow going off the correct position when it stops rotating (OFF state). If this is the case, magazine won't turn when you give it a command.
    Dec 2011
    solution
    hello
    The solution of this failure is simple .
    on the distribution board are a number of plug or print relays placed.
    print relays 12 and 13 are for running the tool changer. One of the relays was faulty. the 4 toolchanger relays have been replaced and the fault is corrected.
    Gentlemen, thanks for sharing the knowledge.
  1. VMC600 table removal
    By smellyfeet in forum Bridgeport / Hardinge Mills
    Last Post: 10-24-2011, 02:16 PM
  2. Looking for X,Y,Z DRO for Bridgeport
    By ogesII in forum Want To Buy...Need help!
    Last Post: 12-04-2009, 05:43 AM
  3. VFD for Bridgeport?
    By M Spangler in forum Phase Converters
    Last Post: 12-28-2008, 02:27 AM
  4. bridgeport cnc
    By toolclaw in forum Uncategorised MetalWorking Machines
    Last Post: 12-17-2008, 05:23 AM
  5. Bridgeport DRO
    By gbowne1 in forum Bridgeport / Hardinge Mills
    Last Post: 05-30-2006, 05:07 PM
