586,119 active members*
3,570 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Gerber 408 motor stops running no error message
    Jan 2010
    Hello All,
    I have a Gerber 408. When we run a job it starts fine but after about a minute the spindle stops running but the X & Y keeps going. Anyone have this issue before?
    May 2008
    85
    Not happened to me.
    Sometimes when the spindle stalls it will stop but then I will get an X or Y axis failure and need to reboot.
    What size spindle?
    What material? Speed? Feed?
    Is this consistent?
    Any error codes on the VFD?
    Jan 2012
    Hello Comeco,
    we also run a Sabre 408 and have just experienced a similar problem as described in your post of 12-05-2011 : right in the middle of a job the spindle stops running but x any keep going.
    We wonder if you have solved this problem and would be grateful if you could let us know.
    Best regards.
    Jan Dewever
    Maessen plastics
  1. "master encoder state error" AB ultra100 error message
    By ShapeShaver in forum Servo Motors / Drives
    Last Post: 07-31-2013, 04:09 PM
  2. Replies: 2
    Last Post: 09-13-2010, 07:52 PM
  3. EzPath 1S Stops Error?
    By zruss in forum Bridgeport / Romi Lathes
    Last Post: 03-04-2010, 04:17 AM
  4. Replies: 0
    Last Post: 01-22-2010, 09:07 PM
  5. Running g-code on gerber sabre 408
    By precise graphix in forum G-Code Programing
    Last Post: 08-04-2008, 07:37 PM
