Here is the file for the standoffs I am needing. Need 100 to start with.
What material? 'Aluminum' is not quite sufficient. Is T6 OK?
What are the tolerances?
Can the piece be made from .25 square stock? It would be a lot cheaper that way. Even .25 wide and ~.20 deep -- face off one side of the square -- would bring the complexity and price down a lot.
How deep is the hole in the bottom?
Am I correct to assume that the point is two flats, parallel to the two sides?
Jim Hurlburt
Yakima, WA
Job awarded. Thanks for the quotes
