586,070 active members*
3,500 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > 1992 Haas vf-2 this is insane...
Page 1 of 2 12
Results 1 to 20 of 23
    Sep 2011
    Exclamation 1992 Haas vf-2 this is insane...
    Hello,
    I have a 1992 Haas vf-2 that I am about to melt down for scrap and build a toilet with.
    About 3 weeks ago I turned on my machine and all I saw on the screen was snow. In the top left was a blinking square kind of like a DOS prompt.
    I left the machine alone for about 3 days and the powered it again and it worked!
    But yesterday the same thing happend. I have a snowy screen with a flashing DOS square in the top left.
    Ohh and even when I push buttons it does not beep or do anything.....
    Any help?
    I can see the plunger down the hall.........
    :drowning::drowning::drowning::drowning::drowning:
    Jul 2005
    12177
    Have you checked the power supply for the main control board?
    Sep 2011
    Hello, Yes
    Hello, I have checked the powersupply, but there are many of them, can you point me in the right direction, I was on the phone with the tech and the power to each supply is there....
    Thank you for the reply
    Apr 2005
    713
    Does a simple power down / power up clear the screen? Mine does that occasionally, and has since day one. Takes a minute to deal with.
    Oct 2007
    106
    Cool EPROM
    Before you make your toilet
    could you read all the EPROMS of the processor board and email them to me,
    please?
    We have a 1990 VF-1 that could make a nice toilet too... :devious:
    This are the symptoms:
    It hangs out at random.
    I think that the EPROM might be corrupted, because:
    1) If I press the Alarm button twice, the screen shows garbage.
    2) When the mill freezes the RUN led of the processor board goes out.
    3) It has new processor & video boards, but with the original EPROM
    4) I still freezes with all memory and parameters erased, and with all servos and encoders disconnected.
    5) I read all the EPROMs, burned them in new chips, still the same.
    But the fact that it does not freeze always at the same point tells me that it is not a software issue. Can it be?
    Any ideas?
    Has anybody ever attempted to replace the Haas boards with a PC? (Mach3, EMC2)
    Regards:
    Everardo Rascon
    Auto-Tec
    Nov 2005
    56
    My money would be on the power supply.
    It looks like a PC power supply (because it is) but it has slightly modified internals. Haas do a replacement.
    Sep 2011
    Hello
    If its the power supply, how would I suspect it is? Just hook up an oscope to each voltage output?
    Sep 2011
    Quote Originally Posted by erd39030 View Post
    please?
    Any ideas?
    Regards:
    Everardo Rascon
    Auto-Tec
    If you show me how to download the eeproms I will send it to you, I have rs232 port also...
    Nov 2005
    56
    Quote Originally Posted by mikemike^3 View Post
    Good quality meter onto each of the outputs, from memory it was the power supply to the mocon that went on ours.
    Sep 2011
    Quote Originally Posted by Matt@RFR View Post
    Hello, no powerup/down does not fix the issue.
    Sep 2011
    Quote Originally Posted by BigNizzy View Post
    I will check the power supply with all the outputs disconnected (cabling off) and check for power to each. is it 5v? or 12v? 24v? not sure....
    Nov 2005
    56
    From Memory it's a mixture of 5v and 12v the manual should help.
    Sep 2011
    Im gonna check it now and get back to you guys give me about an hr. Thnx
    Sep 2011
    well.........now it works! this is crazy.......I hate electrical gremlins :devious: Im gonna check voltages and get back with ya guys
    Dec 2008
    717
    Try unplugging it then plug it back in...lol - isn't that the normal helpdesk reply?:banana:
    Glad you are up and running again - but sounds like you may still need to check out those power supplies or you may be up the creek again. Still, though...a '92 machine?! That is some ancient stuff man!
    Tim
    Oct 2007
    106
    Thanks Mike.
    But you shoulnd't mess with the EPROMS until you are ready to scrap your machine, not because it is difficult, but because of the risks involved.
    To read the EPROM chips you need a programmer like this:
    PCB5.0E SMD Willem EPROM programmer,BIOS,PIC,ShipfrmUSA | eBay
    Then you have to remove the EPROM chips from the boards and read them with the programmer.
    The risks are that if you handle the boards incorrectly, you can damage the ICs due to static electricity, or bend/break some pins. Also, if you put wrong the chips in the programmer, or if you configure it incorrectly, you can short circuit/burn them (flame2)
    Anyway, it is fun to tinker with the stuff we are not supposed to tinker with... :bat:
    Sep 2011
    Very true, its working now, ill leave it alone, the next time it happens. ...(chair) (to the machine tho...)
    Feb 2010
    1184
    When you were checking the voltages, did you actually unplug the cables and put them back on? If so, sometimes that alone clears up many voltage related problems. The connections get a little oxidised and the friction of disconnecting and reconnecting the plugs can restore the connection to deliver good voltage again.
    Feb 2008
    217
    A word of caution:
    Switching power supplies (as opposed to linear type ) require a load any time they are powered up and WILL usually go up in smoke if operated without a load. Some of the newer ones have internal load resistors to protect them but not all.
    Oct 2007
    106
    Quote Originally Posted by Joe S. View Post
    A word of caution:
    Wow!
    There´s always something new under the sun.
Page 1 of 2 12
  1. Replies: 15
    Last Post: 03-12-2011, 07:53 AM
  2. Another insane request
    By christinandavid in forum Fanuc
    Last Post: 08-23-2010, 02:46 PM
  3. Need 1992 Haas VF0 drive board ASAP!
    By jrudicel in forum CNC Machining Centers
    Last Post: 09-29-2007, 02:05 AM
  4. Being driven insane by an offset problem!
    By Cold Fusion in forum Uncategorised CAM Discussion
    Last Post: 09-12-2004, 04:39 AM
  5. Am I insane for being here?
    By kcoaks in forum DIY CNC Router Table Machines
    Last Post: 04-03-2004, 04:53 PM
