586,068 active members*
3,876 visitors online*
Results 1 to 8 of 8
    Aug 2005
    300
    Trimming in v24
    I am having a problem when trimming. This is intermittent. When I select Utilities, Trim Extend and then try to perform this operation the screen goes to zoom. At this point I cannot see anything. I then select Zoom Fit All and my drawing reappears. The cycle just keeps repeating itself. Very frustrating. Is there any way that I can prevent the screen from zooming when not called for. Do I have some setting set wrong?
    Ernie
    Aug 2005
    300
    Talking
    Anybody???
    Ernie
    Mar 2010
    1852
    Quote Originally Posted by ErnieD View Post
    Anybody???
    Ernie
    It is very possible that no one else is suffering from this. What trim select function are you selecting?
    Mike
    Jun 2008
    1838
    Anybody???
    Ernie
    Hi Ernie
    Nope, sorry, tried to re-create your problem here but couldn`t in either V23 or V24
    Try support ? ? ?
    Regards
    Rob
    :rainfro::rainfro::rainfro:
    Aug 2005
    300
    Posted on the support forum, no luck.
    Ernie
    Dec 2008
    4548
    Sounds like video drivers.
    Aug 2005
    300
    Upgraded video driver and now the software will not even open.
    Ernie
    Jessebobcad Guest
    It is possible there is a corrupt file in your installation. Has this issue just started? If you could take a video of the issue and post it or send it to [email protected] we should be able to solve it for you. Did you also run windows update as well?
  1. Trimming in an assembly
    By Farmers Machine in forum Uncategorised CAD Discussion
    Last Post: 03-21-2011, 05:10 PM
  2. Trimming Circles and Lines
    By jcnewbie in forum Mastercam
    Last Post: 01-07-2010, 03:18 AM
  3. Trimming surfaces
    By dpark1 in forum Mastercam
    Last Post: 07-27-2009, 05:54 PM
  4. router trimming
    By snocutt in forum Employment Opportunity
    Last Post: 08-21-2008, 06:46 PM
  5. Trimming in bobcad
    By Parameter in forum BobCad-Cam
    Last Post: 12-30-2005, 10:07 PM
