I have a question regarding the hr450 indexer home position.
When a G28 is performed on the a axis it returns the indexer to a set home position.
Is it posible to change or reset that home position.
thanks
caddisfly
thanks
caddisfly
I do not know of any way to change the G28 home position but you can use G53 to move the rotary to whatever position you want.
If you have Quick Rotary G28 on your machine so it homes to the nearest position instead of unwinding several revolutions you would have to use G28 first then the G53 move to the position you want.
