587,006 active members*
2,971 visitors online*
Results 1 to 13 of 13
    Jun 2006
    48
    controlling 5 axis milling machine - software
    Hi everyone,
    I would need some suggestions about control software to use for 5 axis milling machine with 2 axis rotating head.
    For now I am using mach3 bit it has a big disadvantage, in case I am running full 5 axis g-code, there is no kinematics implemented for tool length compensation, so now I am solving this with g-code which has already included kinematics, but that is time consuming in case of tool change etc...
    I know for camsoft's solution, but it is a bit expensive for "home use" machine...
    Feb 2009
    2143
    Flashcut
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Dec 2005
    600
    EMC2.
    Mark
    Jun 2006
    48
    Quote Originally Posted by wendtmk View Post
    EMC2.
    Mark
    You maybe know for anyone who actually uses EMC2 on similar 5 axis milling machine?
    A searched over the web for it, but there is not much information about that, even basics that I could believe this would work in my case.
    Jul 2003
    1754
    there are a few..
    EMC2 cinci test cut - YouTube
    [ame=http://www.youtube.com/watch?v=QGyxnafLbcw]CNC 5axis with EMC2.wmv - YouTube[/ame]
    [ame=http://www.youtube.com/watch?v=aF7C8d4d0nc]Homemade 5 axis machine, running EMC2, in XYZAB configuration - YouTube[/ame]
    [ame=http://www.youtube.com/watch?v=DjPCEpZybXs]5-Axis CNC Mill @ Hogeschool Antwerpen - YouTube[/ame]
    might want to join the mailing list and ask questions. I am no expert on kins..
    sam
    Dec 2005
    600
    Ah good!
    I was hoping Sam would jump in here.
    Mark
    Jul 2003
    1754
    There is a 5 axis kins simulator in emc. (I have not played with it)
    one thing that you can setup in the kins is UVW (the way I understand it) as xyz at the tool tip. So you can do drilling cycles and such using that.
    Kins take some programming ability as you need to set the kins up to your machine. (something to think about)
    the large 5 axis machine above in the video - he is actually using kins to correct out of squareness and sag.. Very powerful.
    sam
    Jul 2003
    1754
    Jun 2006
    48
    I will give a try to EMC2, looks very very promising!
    I also contacted Falshcut via email, but no answer from them till now...
    Jun 2006
    48
    So, it took me some time to get into, but it was worth ... EMC2 runs my machine, as I expected!
    Jul 2003
    1754
    Video!!!!
    Quote Originally Posted by Tomax View Post
    Aug 2011
    19
    hey tomax,
    what machine did you actually build? i'm looking at buying a kit to assemble a 5 axis with a 2 axis rotating head....any suggestions?
    thanks ,d
    Jun 2006
    48
    Quote Originally Posted by samco View Post
    Video!!!!
    Here is video of running test code, milling impeller
    Quote Originally Posted by diegope View Post
    hey tomax,
    thanks ,d
    If there is an interest, I might sell mine... machine was built in a way that it is possible to disassemble it.... its dimensions are 2.4x1.7x2.1m
  1. Controlling a 6 axes Robot, what software?
    By satanicoo in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-03-2010, 03:15 AM
  2. Have Made PCB Milling Machine, Need help with Software
    By zaidpirwani in forum PCB milling
    Last Post: 04-20-2010, 05:16 AM
  3. Software for 4-axis Milling
    By jconaway in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-05-2009, 11:49 PM
  4. controlling a small six axis machine....
    By neeboy in forum DIY CNC Router Table Machines
    Last Post: 03-31-2008, 08:26 PM
