We have a part we're machining - it starts as a 2.5" cylinder of 6061 AL and it's machined to an octagon like shape. It's 1" high and machined to a final size of around 2.25. It's being machined on a bridgeport series 1 with a retrofit CNC control. It has mist coolant but we have not been using it - we've been machining dry.
The problem is that the exterior finish on the sides (where the mill is side cutting) is not as good as we'd like. Its rippled and has sort of twisting lines to be seen running vertically - like you can see the cuts the mill took out of the material. I can feel them easily when I run my fingernail over them.
We're running 1600rpm with a 2 flute TiN 3/4 inch mill. I will have to check the feedrate but I believe it is around 15ipm - we let MasterCAM choose the RPM and feed. The machine tops out at 4000rpm and 80ipm feedrate.
What can I do to improve the finish? It's a cosmetic piece and the problem is that if the finish is not good it requires a lot of sanding which ends up rounding over the corners and making it look not so good. I am hoping to do as little finishing as possible and get the best finish off the machine as possible. We tried doing a slow speed 4000rpm very light cut finishing pass without much luck. My assertion was that we should do the finishing pass at a relatively high feedrate to avoid overheating the mill, my coworker disagrees (were new to CNC machining) and kept turning down the feed on the high RPM light cut finish pass but it didnt really make it look any better.
Should I use a different helix angle? I dont know what it is on this mill, it was just a cheap mill we had lying around.
Would going to a solid carbide mill help? Maybe someone could recommend a brand for a nice finish? This mill was one we had lying around, came in a set from Grizzly so I know its a super cheap chinese import
Will mist coolant help? I would have to rig up something to do flood and it would be a hell of a mess on the open machine.
What should the feed and speed be and what about how much material to remove to best finish? The part is already machined out of the cylinder and we leave a little "meat" for a finishing pass, so we can do a finish pass at whatever amount of cut depth we want. We're doing the finish pass at the full 1" depth of the part but I mean we can adjust how much material we are removing in the finish pass.
Any other ideas to get a nice finish? I know this ain't a high-end Mori but it's all we've got until these parts start bringing in the $$ and we can get a newer fully enclosed machine, and I know this machine can do better, so anything you guys can suggest would be helpful!
