586,072 active members*
4,682 visitors online*
Results 1 to 10 of 10
    Dec 2011
    10
    Multicam 3000 help anyone?
    I have a multicam 3000 & I am getting a "motor error 23 xa, y, z" when booting the machine up. The last thing it tries to do before it crashes is " enabling motor drives". Will not allow you to initiate home settings. It is kicking out the contactor to the AC drive when trying to set the Z axis. Any Ideas?
    Regards,
    michael
    Jun 2010
    463
    Sounds like your Bridge Rectifier is bad....
    Dec 2011
    10
    Thanks for responding... tried it... no luck though.
    Changed it out & it kicked the switch off. Still no power to servo #1. unhook one side of the capacitor & it don't shut down.... Ever heard of a capacitor go bad on one of these things?
    Michael
    Jun 2010
    463
    Just curious do you verify that the bridge rectifier was installed in the right orientation, if install reversed the same error will happen.
    Dec 2011
    10
    multicam 3000 help?
    I have a multicam 3000 & I am getting a "web fault error" when booting the machine up. It is kicking out the contactor & the circuit breaker to the AC drive as soon as it tries to " enable motor drives". Will not allow you to initiate home settings. If you try to set it by the Hand controller pad it gives error "24 volts over current" We changed out the bridge rectifier, Contactor, capacitor & the mother board. Any help would be great.
    Regards,
    michael
    Dec 2011
    10
    Multicam 3000 motor fault
    Hi, just wondering if anyone had any ideas? I am getting a motor fault (0x 4)
    Drive 3 (z) Blink count 5
    It gives me that error when trying to home machine.
    Thanks for your time.
    Mike
    Jun 2010
    463
    Multicam 300 help anyone?
    Blink count 5 is normally a mechanical issue,
    1. Z-screw is dirty
    2. Z servo is dirty, sometimes your material that you are cutting get down into the upper bearing of the servo.
    3. Bearing cars are shot and need replacement.
    4. Ball screw itself has blown bearings and needs replacement.
    5. The pulley on the top of the z-screw has shifted and is rubbing against the top to the support plate. EASIEST TO CHECK
    WORSE CASE:SERVO AMP IS SHOT, and needs replacement.
    Dec 2011
    10
    Thanks for your help.
    Thanks for the information :cheers: The bearings on the ball screw are shot!
    Thanks again,
    Mike
    Dec 2011
    10
    Exclamation Multicam 3000 motor fault blink count 11
    Multicam 3000 motor fault Multicam motor fault (0x 4
    Drive 3 (z) Blink count 11:stickpoke:stickpoke
    Mike
    May 2013
    did you ever get an answer, how did you resolved it? I'm having the same problem.
  1. Multicam 3000 shutdown
    By Lilgedahl in forum DNC Problems and Solutions
    Last Post: 10-27-2018, 07:49 PM
  2. servo error - MULTICAM 3000
    By ugan.git in forum Commercial CNC Wood Routers
    Last Post: 04-04-2012, 04:12 PM
  3. cnc multicam 3000 problems
    By jorgemadrigal in forum Uncategorised MetalWorking Machines
    Last Post: 10-20-2010, 06:06 PM
  4. Multicam 3000 not communicating
    By nwsigns in forum Commercial CNC Wood Routers
    Last Post: 10-05-2010, 11:40 PM
  5. Multicam 3000 Nightmare
    By angelocmp in forum Waterjet General Topics
    Last Post: 08-30-2007, 02:32 AM
