586,072 active members*
4,659 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Tool collision but not really?
    Mar 2009
    1114
    MasterCam is telling me the tool is colliding with the stock but when I run the verify everything looks good and no collisions. I don't understand whats going on here? I don't want to try and run the part and see it get f'd up. Any ideas?
    Dec 2008
    3109
    I'm guessing it is a combination of the "Tool Clearance" settings ( stock setup page in Op manager -read the ? in this area ) & your use of the lead in/out settings ie Rapid moves set to 0.050" and the lead in set to 0.040"
    Tool clearance sets a "phantom" boundary" ( around the stock, chuck & tailstock ) to check back to, for the transition ( rapids ) between passes. 9 times out of 10 it turns out only to be a warning, not a crunch.
    .........It's the 1 out of 10 that bits you on the bum.
    Jan 2010
    107
    ive had exacly the same problem.. always only got the error when i made the toolpaths... but when i used verify and checked for tool collision it dident say anything and out on the machine no collision.
    I was thinking what i did wrong aswell.
  1. Help heidenhain collision
    By Gearhead123 in forum CNC Machining Centers
    Last Post: 07-11-2011, 05:38 PM
  2. Help heidenhain collision
    By Gearhead123 in forum Uncategorised MetalWorking Machines
    Last Post: 07-09-2011, 12:16 PM
  3. Collision warnings
    By cgroves in forum SprutCAM
    Last Post: 06-22-2011, 01:36 PM
  4. Collision / Gouge check
    By coykiesaol in forum Mastercam
    Last Post: 12-25-2010, 07:03 PM
  5. tool holder collision check
    By javed08 in forum PTC Pro/Manufacture
    Last Post: 10-04-2007, 04:42 PM
