586,103 active members*
3,278 visitors online*
Results 1 to 7 of 7
    Oct 2011
    19
    Okuma OSP5000-LG Tapping
    I have an Okuma LB-10 and am getting started on my second project ever. I will be tapping a 10-32 thread into 300 series SS.
    The only code I have found in the book for tapping is G-184 but it does not define any variables to be used with it.
    I would appreciate a simple example for tapping using this code.
    Also, is there a way to peck-tap with this code?
    Thanks in advance for the help.
    Feb 2009
    6028
    Is this a lb10m?
    Oct 2011
    19
    I don't think it's an LB-10m. It's an 88 model if that helps.
    Feb 2009
    6028
    M is milling. If you don't have milling, you will need a floating holder. No peck tapping without live tool. I'll look up a tapping cycle tomorrow, I used to just program with igf.
    Aug 2008
    62
    G77 For right hand thread
    G0G95G97X15.Z15.S75T0101M41M3
    X0.0Z1.1
    Z.375M8
    G77X0.0Z-.75F.03125
    G0Z1.1
    X15.Z15.M9
    M30
    G78 For left hand thread
    G0G95G97X15.Z15.S75T0101M41M4
    X0.0Z1.1
    Z.375M8
    G78X0.0Z-.75F.03125
    G0Z1.1
    X15.Z15.M9
    M30
    Feb 2006
    1792
    I do not know about your control, but Q is used for peck tapping on Fanucs, defining peck length.
    Oct 2011
    19
    Thanks Thawk53.
    G77 worked great!
  1. OKUMA OSP5000
    By neko911 in forum Okuma
    Last Post: 03-04-2012, 03:21 PM
  2. Replies: 9
    Last Post: 09-09-2011, 11:57 AM
  3. Okuma internal tapping breakage
    By edirig1 in forum Okuma
    Last Post: 03-20-2011, 01:25 AM
  4. Okuma OSP Tapping Cycle
    By pyropainter in forum G-Code Programing
    Last Post: 04-24-2010, 07:09 AM
  5. Okuma Osp5000
    By hien100881 in forum G-Code Programing
    Last Post: 11-28-2007, 05:59 AM
