586,655 active members*
2,841 visitors online*
    Oct 2004
    11
    Rock and Stone faces
    I need to generate a solid model for some molds which are split rock and stone. Like a castle wall. I need to generate the rounded chipped surface so I can make a mold. What software should I be looking at to generate these types of surfaces to be machined. I'm looking for something canned that would take alot of time on my part editing the surfaces. Thanks
    Sep 2003
    111
    I don't know if there is anything that is totally "canned". But I sent a few minutes using VS3D to come up with this:
    I started with a rectangle, added a bevel, some random texture, and a few ridges and depressions. Once I had a rock finished, I stacked three of them and then did an automatic nesting (Allowing 180 degrees of rotation). So all the rocks in the wall are the same, but some are actually inverted. All in all, it took less than 10 minutes to build the surface.
    I assume you are interested in carving concrete forms ?
    VS3D home page: http://www.designscomputed.com/vs3d
    Daniel Carr - President,
    Designs Computed, LLC
    Oct 2004
    11
    This looks like it may get the job done. Can I do such from a digital picture or BMP file? Thanks
    Sep 2003
    111
    Yes, if you have a digital photo (BMP, TIF, JPG, etc) you can convert the image brightness to surface height. Like this:
    http://www.designscomputed.com/vs3d/...mg_emboss.html
    Aug 2003
    318
    If you have software for creating a height field from a bmp the I would suggest getting Dosch 3d textures for Stone and Concrete. They contain bumpmaps which is a correctly greyscaled bmp.
    http://www.doschdesign.com/products/...ncrete_V3.html
    Donny
    www.whiterivermfg.com
