586,103 active members*
3,205 visitors online*
    Oct 2011
    218
    Speed & feed THEN
    Hi all, I've been cutting aluminum sheet 2.5mm thick on air cooling ok, with the same pump mentioned in Romans posts,so here's my speed / feed that works ok, but very slow indeed . Specs
    3mm 2 flute carbide bit.
    23000rpm. (very loud)
    120mm per min
    Air cooling .
    This seems too cut ok but like stated it's very slow compared to other cuts I see on air on YouTube etc, could anyone recommend some other numbers I could try,
    Thanks all a quicker cut means a happier wife
    Cheers.
    Apr 2010
    294
    On a rigid mill you could go 10 times that. So you've quite a lot of scope to increase.
  1. Tap feed and speed help!!!
    By SSI in forum MetalWork Discussion
    Last Post: 10-18-2009, 09:48 PM
  2. How to set feed speed
    By IMK1230 in forum G-Code Programing
    Last Post: 07-02-2009, 12:41 AM
  3. feed & speed mdf ?
    By frankgranit in forum French
    Last Post: 11-14-2008, 09:18 PM
  4. RPM/Feed Speed 4 Ali?
    By bigz1 in forum Engraving Machines
    Last Post: 05-20-2007, 11:14 PM
  5. Feed & Speed Help
    By kaleem1 in forum MetalWork Discussion
    Last Post: 11-04-2004, 02:21 PM
