586,440 active members*
3,861 visitors online*
IndustryArena Forum > Manufacturing Processes > Safety Zone > Plasma cutting galvanized steel. Water table or downdraft?!
    Nov 2011
    hey, I'm new to the CNC scene. From what I know, welding galvanized steel creates some toxic fumes. Are there any dangers of plasma cutting galvanized steel on a water table? Is there a possibility of something similar as to explosive hydrogen pockets being trapped between the water and plate as in cutting aluminum?
    I'd rather put together a water table than a downdraft system. I will mainly be cutting mild steel and galvanized.
    Thanks.
    Jan 2008
    2247
    While plasma /cnc machines that are built for cnc plasma cutting of galvanized steel for the HVAC market all use downdraft tables (keeps the water stains off the sheets)....there is no reason why galvanized cannot be succesfully cut on a water table...the water sould be right at the bottom of the sheet.
    When cutting of aluminum on a water table there is a reaction of the aluminum oxide particles that settle in the bottom of the table...these particles absorb oxygen from the water...leaving hydrogen. Hydrogen bubbles rise in the water and easily and safely dissipate in the air under normal conditions...however if there is a place that can trap the hydrogen and a large pocket accumulates...then there could be an explosion issue. The zinc from the galvanizing coating will not do the same thing.
    Jim Colt
    Mar 2008
    LEV and Plasma Cutting
    I am sure that a water table is best for nearly all small general purpose cutting tables. You would need a HUGE air flow to get rid of all the tiny particles caused by plasma cutting- water just mops them up. Beware of possible Legionnaires disease and change water regularly - in the UK we have to use a chemical bacterial inhibitor. I also use a corrosion inhibitor in the water -helps if you leave mild steel in for a few haours.
    Graham
    Oct 2012
    193
    Water table is basically helpful for capture smoke and dust created by plasma cutting machine process. Plasma cutting machine can give you best result on galvanized but still has the poison smoke. But downdraft is less efficient to capture smoke and dust. But downdraft table is efficient to cut galvanized and wide range of metals.
    www.ajancnc.com
    Jan 2008
    2247
    Actually the worlds largest market for cutting of galvanized steel is with HVAC (heating, ventilating and air conditioning) contractors. The machine of choice for cutting ductwork fittings from galvanized is a cnc plasma cutting machine with a downdraft fume control system. There are close to 10,000 of these machines in operation in the world today. I am not aware of more than a couple that use a water table...they are downdraft, and very effective at removing hazardous fumes.
    A properly designed downdraft table has no fume control issues, and eliminates the issues associated with rust, water stains, as well as disposal of contaminated water.
    Jim Colt Hypertherm
    Quote Originally Posted by GrahamSwindley View Post
    Graham
  1. A Different Machine - Downdraft/water table
    By flyinwilly in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 10-02-2021, 02:46 PM
  2. Combo Water/Downdraft table.....got any ideas?
    By douglasco in forum Waterjet General Topics
    Last Post: 04-29-2009, 11:39 PM
