586,094 active members*
4,116 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > RS232 communication
Results 1 to 6 of 6
    Oct 2007
    74
    RS232 communication
    We have many older Hurco machines both Max 2 and Max 3 era. We have lost the disk drives on a couple of the older Max 2's and are finding it harder and harder to find replacements. I am wanting to use the RS232 communications to try back up the programs and was trying to use Procomm the same as I do on an older Nagitta mill. I was hoping someone could help and let me know if this could be done. I know you can use the Conversational up/down program from Hurco but I was hoping to be able to keep using the program we are currently using (Procomm) to do the same. Thanks
    Feb 2008
    48
    Follow this link to the Hurco Web Page FAQ's
    Support FAQs - HOW TO HOOK UP A RS 232 CONNECTION TO A HURCO...
    Oct 2007
    74
    Brock,
    Thanks for the advise. I have gone over the procedure and notice it needs to use the HD3 Serialize utility. I tried to find this on the FAQ site with no luck. Do you have any suggestions as to where I can find it. Thanks. John
    Feb 2008
    48
    Yes,
    Send a request to [email protected] requesting the program.
    Note it was only designed to run in DOS, Win3, and will run in Win Xp also.
    Oct 2007
    74
    will do, thanks again.
    Apr 2010
    27
    Re: RS232 communication
    I have several machines equipped with FANUC CNC but I have one with HEIDENHAIN CNC.
    With FANUC CNC I use “communication software for FANUC CNC” application that work with all windows platforms (I tried with windows XP, windows 7, and windows 10),
    I downloaded from this site:
    Communication Software for FANUC CNC Download
    It works well with all FANUC CNC: RS232C connection (for old CNC) and Ethernet connection (for the new ones) but I cannot get it work with HEIDENHAIN CNC.
    Do you know any communication software that works with HEIDENHAIN CNC?
  1. Online communication with RS232
    By serdarakkoyunlu in forum DNC Problems and Solutions
    Last Post: 11-14-2021, 12:01 PM
  2. RS232 Communication Problem
    By Fighter in forum Dynapath
    Last Post: 07-23-2020, 10:25 AM
  3. Fanuc OT RS232 Communication
    By Mike M in forum Fanuc
    Last Post: 02-28-2014, 10:41 PM
  4. USB to RS232 NO Communication?
    By frz400 in forum DNC Problems and Solutions
    Last Post: 10-23-2008, 11:16 PM
  5. RS232 communication software
    By gar in forum Haas Mills
    Last Post: 08-14-2007, 02:56 AM
