586,110 active members*
3,336 visitors online*
    Jul 2006
    143
    How to make a backup disc/ ezpath 1
    I need to back up the software on a ezpath 1. How do I do this?
    thanks
    i_r_machinist
    Jul 2007
    45
    Assuming the Ez-Path 1 has a hard drive I will try to give this a shot. I'm pretty sure you mean back up the Ez-Path software and not just part programs. If you are the least bit familiar with computers the easiest would be to just take out the Ez-Path hard drive. Install it as a second drive in another older Windows computer that still has an ide/ata interface. The whole drive or any part of it can then be copied or the drive cloned. If you don't have an old computer to install it in, there are USB to sata/ide hard drive adapters available. These allow an ide or sata drive to be connected to a "newer" windows computer via a USB port. [ame="http://www.amazon.com/USB-2-0-SATA-Converter-Cable/dp/B001OOXBDO/ref=sr_1_fkmr0_2?s=electronics&ie=UTF8&qid=1324594 156&sr=1-2-fkmr0"]Example one of many[/ame]. In my opinion this method is much simpler than trying to use floppies.
  1. help for ezpath ++
    By mmckell in forum Bridgeport / Romi Lathes
    Last Post: 01-29-2010, 04:21 AM
  2. Ezpath
    By camtd in forum FeatureCAM CAD/CAM
    Last Post: 02-17-2009, 07:04 AM
  3. Replies: 1
    Last Post: 11-28-2008, 03:22 PM
  4. EZPath II CSS problem
    By Gncc50 in forum Bridgeport / Hardinge Mills
    Last Post: 11-22-2008, 07:43 PM
  5. ezpath fault
    By evo123 in forum Bridgeport / Hardinge Mills
    Last Post: 06-30-2008, 09:42 PM
