586,068 active members*
4,515 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal 4020 mm/um in MDI
    Jun 2009
    146
    When I write something in MDI mode, For each even value is always required to enter a dot.
    For example: When I write: "G0 X40 Y-78",
    this means that: G0 X0.04 Y-0.078 (in mm).
    I have always written like this: "G0 X40. Y-78."
    this means that: G0 X40 Y-78 (in mm).
    I often forget to write a dot, then the coordinates are not true.
    Is it possible to change somewhere in the parameters of this property?
    Feb 2008
    547
    Smile
    No, I don't believe so for two reasons... The numbers are filled from right moving toward the left, it's standard cpu practice. The other reason this is a good idea is, would you want your machine to try and move or rapid 40 inches? Maybe, but most of the time not.
    BTW, in your example for inches... you said, "I have always written like this: "G0 X40. Y-78."this means that: G0 X40 Y-78 (in mm)."
    Conventionally, this x40 and the y-70 will defalt to x.0040 and y-.0070. prameter setting is factory at .0000. Maybe you could change that parameter to .000, but I'm not where I could look it up. Neal most likely can tell you.
    Steve
  1. Fadal 4020
    By joshuac in forum Fadal
    Last Post: 09-10-2010, 11:36 AM
  2. FADAL 4020 Z-AXIS WON'T GO!
    By TRACYPFAB in forum Fadal
    Last Post: 05-27-2010, 02:44 PM
  3. FADAL VMC 4020
    By dmac88 in forum Fadal
    Last Post: 05-18-2009, 08:45 PM
  4. How do I tell the age of a FADAL 4020?
    By Rickady in forum Fadal
    Last Post: 07-10-2007, 12:02 PM
  5. Fadal 4020 resurrection......
    By jnc in forum Fadal
    Last Post: 06-30-2004, 06:22 PM
