586,104 active members*
3,310 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Adjusting time on a Wooden Clock
    Jan 2008
    241
    Question Adjusting time on a Wooden Clock
    Hello all!
    I'm in the midst of designing an electric clock and need some sort of clutching system for time adjustments.
    There is no clutch on the motor.
    There are no conventional 'hands' and the gears will be required to spin to adjust the time.
    I could really use some input with this. Suggestions?
    (sorry for the crude sketchup model, as I'm still learning!)
    Attached Thumbnails Attached Thumbnails Sketchup%2001.jpg   IMG_1185.jpg   Gearotic%20Motion.jpg
    My Build: http://www.cnczone.com/forums/diy-cnc_router_table_machines/113711-my_build_-_many_thanks.html
    Jan 2008
    241
    Nothing?
    I was thinking of two friction disks spring loaded...
    I'll see what I can come up with...
    Dec 2011
    That's what I did on my latest clock, although the disks have one-way gear surfaces.
    Jan 2008
    241
    Thats great!
    Unfortunately, I haven't got that much space to use...
    I have to drive it off the motor itself.
    I posted this question on another forum, and someone
    mensioned a one-way bearing from RC use.
    So I think thats what I'm going to try.
    Thank you for your input!
    How do you make the ridges on the mating faces?
    Dec 2011
    CarveWright.
  1. Wooden Clock Gears
    By wallyign in forum WoodWorking Topics
    Last Post: 04-18-2012, 04:43 PM
  2. another clock
    By balsaman in forum WoodWorking Topics
    Last Post: 05-14-2009, 02:17 AM
  3. So I made a clock too
    By gianluca70 in forum WoodWorking Topics
    Last Post: 12-18-2008, 02:36 PM
  4. using cnc to make a wooden clock?
    By panofish in forum Benchtop Machines
    Last Post: 07-10-2008, 07:27 PM
  5. A cnc clock
    Last Post: 01-26-2008, 08:15 PM
