586,067 active members*
5,176 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Constraining sketches.
Results 1 to 3 of 3
    Jul 2007
    129
    I'm trying to constrain a circle to the origin, but it will not constrain. How I'm doing it is, I choose a circle, click the origin, type in the dimension. But it is still green. What do I need to do?
    Thanks.
    Nov 2010
    45
    (I'm assuming you're using Inventor)
    Create your circle, then make two dimensions, clicking the **center** of the circle and the origin. Once the dimensions are created, change them to 0 and your circle will be constrained to the origin.
    Oct 2006
    222
    you can also draw your circle center point on the orgin, select the center point and click the lock icon in the constraints menu
  1. Derived Sketches - How does one......
    By Aquatic in forum Solidworks
    Last Post: 03-13-2011, 09:47 PM
