586,104 active members*
3,427 visitors online*
    Sep 2011
    54
    Need help calculating stepper motor
    I am trying to tune my plasma table. However, everytime my numbers to come out to be the correct calculation. Could someone please help.
    Direct drive, No reduction.
    my motors are 620 oz nema 23, 200 steps per 1 revolution
    multiply 10 for micro stepping
    .75 pinion gear (20 deg 20 pitch 15 teeth.75 dia)
    I keep coming up with 848.824378
    Really I have come up with different numbers.
    on my Z axis, I have the same motor with
    14 1/2 degree spur gear 24 pitch 21 teeth
    0.875 Dia.
    Any help would be greatly appreciated.
    Travis
    Apr 2004
    5737
    Sorry, that doesn't make sense to me
    Are you sure that pinion gear is 3/4" in diameter, not 3/4" in circumference? A 3/4" circumference gear with 15 pins would be correct for a 20-pitch rack, but its diameter would be smaller than 3/4". Could you measure it and get back to us? If you're talking circumference, not diameter, the calculations for your first axis are pretty simple: (200 x 10) divided by .75, which gives you 26,666.667 (micro) steps per inch, rounded off to the nearest thousandth. (I'll let you do the second problem yourself...)
    Andrew Werby
    ComputerSculpture.com — Home Page for Discount Hardware & Software
    Mar 2008
    195
    20 deg, 20 pitch, 15 teeth, .75 pitch dia. = ( 848.824378236143 )
    14.5 deg, 24 pitch, 21 teeth, 0.875 pitch dia. = ( 727.5637527738369 )
    My Blog
    http://www.needfulthings.net/tulsaturbo/myblog/index.php
  1. Calculating Stepper Motor Torque
    By kdrajan in forum Stepper Motors / Drives
    Last Post: 05-10-2018, 07:59 PM
  2. Calculating stepper current, chopper drivers
    By holyjewsus in forum Stepper Motors / Drives
    Last Post: 07-11-2011, 06:51 PM
  3. calculating stepper motor size?
    By Jon Jessen in forum Stepper Motors / Drives
    Last Post: 08-05-2008, 03:52 AM
  4. calculating size of stepper
    By rofuth in forum MetalWork Discussion
    Last Post: 10-14-2007, 07:04 PM
  5. Calculating Motor Torque
    By creative_mind in forum CNC Machine Related Electronics
    Last Post: 01-08-2004, 05:52 PM
