587,034 active members*
3,353 visitors online*
IndustryArena Forum > CAM Software > ArtCam Pro > laser engraving gray-scale
    Dec 2011
    Hey there everyone I have a few quick questions regarding gray-scale in ArtCam. Does anyone know the proper procedure to export an rlf. file to a gray-scale image that can be used for a 120W epilog laser? Also I was wondering if there is a good procedure to adjust contrast or enhance the gray-scale image for the laser using ArtCam?
    Apr 2010
    12
    Relief - save layer. Select bmp or tif. Brightness and contrast you can change in any raster editor like Photoshop, GIMP, Corel PhotoPaint or other.
    Jan 2006
    2985
    You can also use the artcam relief tools to modify the relief, which will affect the grayscale image.
    Matt
    Dec 2011
    Alright, thank you, ill try both suggestions out!
  1. CMA-6040 Laser Cutting & Engraving Machine by Han's Yueming Laser
    By vksingh in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-10-2017, 12:53 PM
  2. Distinction between laser engraving between special LGP engraving machine when produ
    By CUTCNC in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-21-2011, 09:46 AM
  3. versa laser, laser engraving
    By cadmaniac in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-25-2010, 08:30 PM
