Small SS block with a central core and several metric screw holes. See attached file. Would like quote for five of them. Thanks.
Is the file you sent in inches and 1 to 1 scale? Not sure of the dimensions I am getting are correct.
Sorry about that ... units are in mm unless noted otherwise. Drawing does not print to scale 1:1.
This order has been closed. That was unexpectedly quick btw.
Just curious as why you are using stainless steel for the thermal block? I plan to build my own printer one day too. Why not use aluminium? If you are worried about corrosion, could you use Nickel to get a higher thermal conductivity rating?
Good question! Most likely that option will be explored down the road. These pieces are for prototype machines.
