586,094 active members*
3,861 visitors online*
IndustryArena Forum > MetalWorking > 80/20 TSLOTS / Other Aluminum Framing Systems > What extrusion should I use to build a cnc table?
Results 1 to 11 of 11
    Apr 2011
    43
    I',m considering to setup a table for my cnc machine using 8020 inc. t-slot extrusions (15 series). Is that strong enough for holding and cutting 1/2" aluminum? I'll appreciate your response. Thank you
    Oct 2008
    406
    What size table are you thinking about?
    Bob
    "Bad decisions make good stories."
    Jan 2006
    2985
    I'm gonna go with 3060 extrusion...
    Apr 2011
    43
    Thank you for your responses. The size of the table will be 15" by 36.250.
    Jan 2007
    22
    Quote Originally Posted by EKFER View Post
    Hi Ekfer,
    I'am at the stage where I have my ballscrews, rails and bearings and doing my design. My MC will have 1100mm x 750mm x 300mm ball screws to cut wood and
    aluminium. I think you need bigger sections because this gives greater stiffness and better accuracy. I am using 40x80 (heavy) sections (4 kg/m density) and 120x40 (heavy) section for the y axis gantry section to support the Z axis. I will be using 15mm aluminium toolplate for the gantry sides and end plates. With 3.1nm steppers (427oz) this sould be plenty to mill aluminium to a good accuracy (0.01mm). On the UK mycnc forum there are some useful design spreadsheets to work out the deflection for a given load and box section size.
    Hope this heps
    Mike
    Apr 2011
    43
    The main consideration I have is to maintain a low profile while, at the same time be able to clamp on both sides. How about a 1/2 x 15" x 36.250" anodized aluminum plate with threaded holes? Who makes them?
    Apr 2011
    43
    Friends, I read from Bear5k today that Misumi has a heavier extrusion at a better price. I'll look into it. Again, thank you all for your assistance and recomendations.
    Apr 2011
    43
    Techno Inc. has exactly what I'm looking for (HEAVY DUTY EXTRUSION TABLE PLATE 20375). However, at US $341.00 it is beyond my purchase ability. I'll keep looking. Or, if you find an alternative , please let me know. Thank you
    Feb 2010
    Faztek
    Have you given Faztek.net or Faztek.ca a try? They seem to be less "busy" than 80/20, and will spend the time to make sure that you get what you need.
    Jan 2006
    2985
    Quote Originally Posted by TNUTZ View Post
    Do you deal with 80/20 directly or through a distributor? I have had excellent service through my local distributor, granted my projects are normally $2-5k so I'm sure that helps.
    Matt
    Feb 2010
    Quote Originally Posted by keebler303 View Post
    Matt
    As far as I know, you cannot buy direct from 80/20, so you are stuck with the local distributor. For many small "dollar" jobs, you don't always get the service.
  1. Aluminum T-Slot Build Using Misumi Extrusion
    By Bear5k in forum T-Slot CNC building
    Last Post: 10-07-2016, 11:17 PM
  2. Aluminium Extrusion CNC Router Build
    By joshendy in forum CNC Wood Router Project Log
    Last Post: 01-14-2015, 12:39 AM
  3. Aluminun Extrusion Custom Build
    By AZicuRN in forum CNC Wood Router Project Log
    Last Post: 07-29-2010, 05:56 AM
  4. New build! Gantry style based on Ahren's parts and 80/20 extrusion
    By groomden in forum DIY CNC Router Table Machines
    Last Post: 04-03-2009, 04:40 AM
