586,058 active members*
3,874 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > PlasmaCam > How to wire a new plasma torch to plasma cam??
    Dec 2011
    I just purchased a hypertherm power max 65 for my plasma cam. I unhooked the wiring from the old plasma cutter and reinstalled it into my new machine. I obviously hooked something up wrong as the torch will not ignite when asked to cut. It seems there is a communication issue between the brain box and the plasma cutter. Any ideas? Thank you for the help!
    Jan 2008
    2247
    What model PlasmaCam? (98Z, DHC, DHC2, GoTorch, Samson). Machine torch or hand torch? Is your Powermax65 equipped with the CPC interface port?
    If you are using a hand torch...then refer to the instructions that PlasmaCam supplies with their installation disc. Ther will be some cutting and splicing of wires in the torch trigger switch circuit.
    If you are using a machine torch....you will need the rear panel CPC interface port (this port will not work with a hand torch for safety reasons) and a cable.
    Jim Colt Hypertherm [email protected]
    Quote Originally Posted by Bradsky View Post
  1. Plasma Torch Controller
    By MAS in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 11-19-2011, 11:25 PM
  2. Replies: 1
    Last Post: 08-05-2011, 08:21 AM
  3. CNC Plasma torch?
    By david01130 in forum Waterjet General Topics
    Last Post: 11-02-2010, 12:51 AM
  4. Plasma Torch
    By Dembo in forum Waterjet General Topics
    Last Post: 09-26-2008, 07:27 PM
  5. Plasma Torch and Z Axis
    By krazycnc in forum Waterjet General Topics
    Last Post: 08-10-2005, 10:58 PM
