586,075 active members*
3,989 visitors online*
IndustryArena Forum > MetalWorking Machines > Mikinimech > VFD and AC Motor replacement project
Page 5 of 17 3456715
Results 81 to 100 of 337
  1. #81
    Jan 2006
    58
    Allen, if you're going to scrap the Mikini motor and plan to machine the pulley just lop it off or drill out the motor shaft. You could also try heating the pulley and pressing it off.
  2. #82
    Jul 2006
    367
    Quote Originally Posted by allenj20 View Post
    I know Pete pulled his pulley from the motor himself successfully I would be curious how he did that since it is a thermal fit. If I could do that I could pull the old pulley and machine in to fit a QD bushing or thermal fit for the new motor.
    I used a bearing separator and puller...like this setup....
    heat up the pulley ( I used a map gas bottle from home depot) ....plus the help of a nice impact gun to turn the puller bolt
    To re-install, I wrapped the rotor in aluminum (so the wife wouldn't know what it was) and put it in the freezer overnight. The next day I pulled out the rotor and heated up the pulley really good. It slipped right on
    pete
  3. #83
    Jan 2006
    58
    I'm glad I'm not the only one who uses kitchen appliances for stuff like this. The most use my Jenn-Air Pro Line range has gotten so far is to heat parkerizing solution to refinish some firearms parts.
  4. #84
    Dec 2008
    263
    Thanks Pete, I should be able to swing that. Any recommendation on which bearing separator and puller set to pick up. I think HF might have this one local Bearing Separator and Puller Set and Advance Auto Parts might have this one OTC 4518 5 Ton Bar-Type Puller/Bearing Splitter Set
    Quote Originally Posted by slowtwitch View Post
  5. #85
    Jul 2006
    367
    Actually, my puller and separator came from harbor freight. I like to use the separator due to its nice contact point on the pulley.
    pete
  6. #86
    Dec 2008
    263
    Video update
    You guys are going to love this
    [ame=http://www.youtube.com/watch?v=uQRRweXzSGg]Mikini AC Motor and VFD replacement project Video 4 - YouTube[/ame]
  7. #87
    Jun 2011
    695
    Great Video. So much for press fit. Wife was wondering what I was laughing at!
    Hurco KMB1 Build
    Wholesale Tool 3in1 conversion
    C-Constant
    N-Nonworking
    C-Contraption
  8. #88
    Mar 2011
    525
    Nice!
    Kelly
    www.finescale360.com
  9. #89
    Jul 2006
    367
    LOLOLOLO !!!!!! I was drinking my coffee and laughed a bunch of it up my nose
    pete
  10. #90
    Feb 2009
    2143
    So now the question is, how well is the pulley attached to the spindle?!
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
  11. #91
    Dec 2008
    263
    Another update
    Got the pulley attached to the new motor. I bored it out on the lathe to 0.0015" smaller than the shaft. So the interference fit is class FN-2 according to my machinery handbook. I stuck the motor in the freezer overnight and heated the pulley with a propane torch I was then able to tap the pulley on with a brass hammer.
    It's a good shrink fit it's not going anywhere.
    I got the plate and motor attached to the mill all the fabrication is more or less done. Next is all the wiring.
    I went ahead and ordered Keling's new digital stepper drivers the KL-8070D These things are getting rave reviews so I figure why not plus it will make the wiring that much easier as it has screw terminals for the wiring. I will test the Mikini power supplies and as long as the voltage is good and steady I will keep them otherwise they are out too.
    Pics and video update as well.
    [ame=http://www.youtube.com/watch?v=mf5Xtq-iSRw]Mikini 1610L AC Motor and VFD replacement project Video 5 - YouTube[/ame]
  12. #92
    Jul 2006
    367
    Allen.....Looks Great!!!! I have the Keling 8070d drives on my retrofitted Emco lathe ...they are really nice
    pete
  13. #93
    Dec 2008
    263
    Thanks Pete I think I am getting pretty close now.
  14. #94
    Dec 2008
    263
    So it's moving under it's own power again with the new electronics. So making progress I am sort of stuck on the proximity sensors because I have no data on these. So I am not sure how to wire them to the C23. Anyone have any data on these things?
  15. #95
    24221
    2 wire or 3 wire? any part number?
    Al.
    Albert E.
  16. #96
    Dec 2008
    263
    Al.
    they are three wire it has P1204 and C32H on it.
  17. #97
    Dec 2008
    263
    I think they are 12 volt NPN NO just guessing. Though I did measure the output voltage for the limit switch ports on the mikini part and so I know it's 12 volt
  18. #98
    Feb 2009
    2143
    I think this is the right datasheet:
    http://www.ia.omron.com/data_pdf/dat..._ds_csm468.pdf
  19. #99
    Dec 2008
    263
    ok I figured out how to wire them up I think. Pin 1 is +12V pin 2 is signal and Pin 3 is -12v. The problem I have is that it's active low, but it's high signal is only about 1V which won't work with the TTL logic of this BOB. TTL high is a minimum of 2 Volts. Can anyone recommend a good 5V or 12V TTL output photo interrupter switch for use with a cnc4pc C23
  20. #100
    Feb 2009
    2143
    Allen, I think we are all ready for a video of the machine up and running the new spindle, with now issues... Will that happen this weekend?
    Best of luck to you and keep us updated!
  1. Replies: 1
    Last Post: 03-06-2013, 05:19 AM
  2. Replacement Motor Brushes For Sherline Mill AC Motor
    By Lessons in forum Benchtop Machines
    Last Post: 07-17-2010, 02:34 AM
  3. Replies: 12
    Last Post: 07-11-2010, 03:04 AM
  4. replacement motor for PML&Kollmorgen DC Brush Servo Motor
    By fymroger in forum News Announcements
    Last Post: 10-24-2008, 09:36 AM
  5. Possible replacement motor for an X3?
    By tauntdesigns in forum Benchtop Machines
    Last Post: 05-17-2008, 04:24 AM
