586,395 active members*
2,898 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco KMB1 Manual Downloads
Results 1 to 12 of 12
    Oct 2003
    71
    Thought there maybe some others that might find this useful. I have recently acquired a KMB-1 mill and Hurco was kind enough to send these to me. Was really hoping for a wiring diagram but they don't seem to have one any more.
    KMB1m Operation Manual May 1983
    KMBX1 Operation Manual Oct 1983
    Oct 2003
    71
    Here are a few more documents related to the Hurco KMB1 (KMBX1) mills.
    - Electrocraft servo data sheet for Hurco part number 401-4003-003, Electrocraft part number 0700-02-049, which I think also works for Electrocraft part number 0700-02-089 since the motors have the same Hurco part number on them.
    - General servo wiring diagram.
    - General transformer wiring and power distribution.
    Hopefully these will help someone down the road.
    Attached Files Attached Files
    Oct 2003
    71
    Just got this servo datsheet from Electrocraft.
    Part number 0703-02-089
    Cust Part number 401-4003-003
    Oct 2003
    71
    Just got this encoder data sheet from BEI. Encoder number is MX21-566. Hurco part number I think is 416-0248-010. Hopefully this helps someone down the road. This is what one of my encoders was on my mill. They other 2 are of an older vintage.
    Jul 2011
    14
    wire diagrams
    I may have wiring diagrams for a kmb1. I am in the process of scanning the prints I have. If you are interested, i would share.
    tjs
    Oct 2003
    71
    That would be awesome. You could just post them here so others can find the also.
    Jul 2011
    14
    wiring diagrams
    Here are the 1st batch. I have 30+ prints in all, but I will start with these. unfortunately, my scanner will only do 1/2 page at a time so each print is labeled left & right. hopefully you will find these helpful. if there is a specific page or item you are looking for, let me know & I can get that up asap.
    Also, if there is a better way to share these, I am open to that as well.
    tjs
    Attached Thumbnails Attached Thumbnails figure 7-1 002-2513-051 Control Magnetics 1 of 4  Left.jpg   figure 7-1 002-2513-051 Control Magnetics 1 of 4  right.jpg   figure 7-1 002-2513-051 Control Magnetics 2 of 4  Left.jpg   figure 7-1 002-2513-051 Control Magnetics  2 of 4 right.jpg
    figure 7-1 002-2513-051 Control Magnetics  3 of 4 left.jpg   figure 7-1 002-2513-051 Control Magnetics  3 of 4 right.jpg
    Oct 2003
    71
    How are the scans going? Not sure if you have got the it yet, but I could use the pages that are related to the DC servo power supply.
    -Wes
    Oct 2003
    71
    Just found this for the limit switches on on the mill. Micro Switch 101XK5-1 7944.
    Jul 2011
    14
    more drawings, electrical
    Here ae another batch of hurco electrical drawings...
    Attached Thumbnails Attached Thumbnails figure 7-2 423-6183-001 power supply-tb4-cc harness 1 of 2 left.jpg   figure 7-2 423-6183-001 power supply-tb4-cc harness 1 of 2 right.jpg   figure 7-2 423-6183-001 powersupply-tb4-cc harness 2 of 2 left.jpg   figure 7-2 423-6183-001 powersupply-tb4-cc harness 2 of 2 right.jpg
    figure 7-3 423-6186-001 tb6 terminal assembly 1 of 1 left.jpg   figure 7-3 423-6186-001 tb6 terminal assembly 1 of 1 Right.jpg
    Oct 2003
    71
    Here is the manual for auto-lube pump
    Thanks to Bob_La_Londe for posting this.
    Aug 2014
    Re: more drawings, electrical
    I would be interested in these KMB1 Schematics. I tried to copy the files posted on the blog, but all I get is a very low-resolution scan version.
  1. hurco kmb1
    By adee1066 in forum HURCO
    Last Post: 06-26-2011, 07:47 AM
  2. Hurco kmb1
    By Dfoxaldee in forum HURCO
    Last Post: 10-29-2009, 03:27 PM
  3. Hurco KMB1 dnc
    By mmachining in forum DNC Problems and Solutions
    Last Post: 01-25-2007, 05:06 AM
  4. Hurco kmb1 BTR ???
    By drill in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-10-2006, 06:42 PM
  5. Hurco kmb1 help!!!
    Last Post: 01-03-2006, 06:40 AM
