Originally Posted by
SIGMA7
help! please. how i can make short ascend and descend for z axis on mach 3. the DRO for z axis say +60.0000 when is on top and +0.000 when is down to material. normally +0.0000 is the top of the work piece, but from +60.0000 to +0.0000 is a long travel. i already see some videos on the web for cnc machines with short ascend and descend on his z axis. please help!!!.
On the ALT-6 tab screen right above the Reset button is an axis calibration utility. Click on that and follow the instructions. It will ask you a distance to travel, then you confirm that it moved the distance that you requested. The utility will automatically calculate the proper numbers to put in the motor tuning settings. That should correct your problem.
CarveOne
CarveOne
http://www.carveonecncwoodcraft.com
