586,117 active members*
3,426 visitors online*
Results 1 to 10 of 10
    Aug 2006
    71
    Tuning Viper 200F
    Hi Guys,
    So I have everything hooked up, control power is good, I have communication with the drive, and I started to tune them. My power supply is giving the card 126V DC.
    I start with the recommended Kp, KD, I and L.
    I set the Loop to 6, and the I to 0. I start increasing the Kp, and I get to around 750 or 800 and the motor is really stiff, and then if I bump the shaft it starts to oscillate, and before I can change the KD, the motor goes oscillation crazy and faults the drive, and then I get the 5 Red LED flashes.
    The motors are Fanuc 5M's from a Matsuura
    Anyone have any suggestions?
    Andy
    Aug 2006
    71
    Anyone?
    Feb 2007
    966
    Are you increasing Kd at KP x 2 (if Kp is 800 then make Kd 1600) ? Have you left Ki low (below 5)
    Be sure to set Kd before bumping the motor !
    Also fine tune the L parameter better before pushing up the Kp gain. A large oscillation means L isn't at its best setting.
    Larry
    Aug 2006
    71
    Hey Larry,
    So far these are my settings for the X and Y axis which have the 5M motors.
    Kp = 350, i = 3, L=4, Kp=800 I think, and I have the jumper for the 4x Multiplier in as well.
    They seem to be working good. I do think I have a problem with one drive though, because when I try to talk to it the LKR doesn't come up like the other two, and it "freezes" and I cant do anything, i can usually do one command and then it puts a space in between the cursor, I tried 2 different keyboards and powered up/down twice as well. See the attached pictures.
    I am sure I will have to play with the tuning more. When I was testing some settings and I had the Kp at like 550 or 600 and the KD was 1100 or 1200 the servo would be having vibrations or extremely small oscillation, so I started over and decided to try the smaller settings, since I am running 126V DC.
    Any Thoughts?
    Attached Thumbnails Attached Thumbnails 20111231_162122.jpg   20111231_162136.jpg
    Feb 2007
    966
    I havn't see one freeze up as you describe.
    Check the 5 pin connector for good connections , maybe a bent pin ? Or try an other computer.
    Aug 2006
    71
    Larry,
    I tried my office computer, same thing. Can I mail it back to have you take a look at it? Also I will probably be ordering a spare drive as well!
    Thanks.
    Feb 2007
    966
    Sure, email me and maybe i can send the new drive with a replacement for that one.
    Feb 2007
    966
    Quote Originally Posted by Trucks
    I received the drive yesterday, and fixed it today. It was a funny problem, it would add a 'space' on its own.
    Turned out that 2 SM capacitors got mixed up on the Max232 circuit for the RS232.
    Larry
    Aug 2006
    71
    Cool! Can't wait to get it back!
    Aug 2007
    16
    hi Larry
    i do not want to sidetrack from the original question
    i bought 4 viper 200 around 2 years ago (i live in Grimsby , Niagara Region) and use them since with my old AH-HA controller.
    you hinted that you might have a tuning software availabe for an easier setup.
    any hint if?
    hans
  1. Tuning viper drives Ver 2.8H
    By damelman in forum Viper Servo drives
    Last Post: 04-29-2011, 10:52 PM
  2. Viper order
    By biomed in forum Viper Servo drives
    Last Post: 11-26-2010, 07:53 PM
  3. viper or gecko's?
    By diyengineer in forum Servo Motors / Drives
    Last Post: 03-12-2010, 01:52 AM
  4. More Viper problems
    By kilrabit in forum Viper Servo drives
    Last Post: 02-24-2010, 01:53 AM
  5. viper 200 tuning for SEM MT30M4-59 servo motor
    By cwaugs in forum Viper Servo drives
    Last Post: 09-04-2009, 03:01 AM
