586,089 active members*
3,876 visitors online*
Results 1 to 5 of 5
    Feb 2005
    30
    affordable, stout, spindle
    I'm looking for the best bang for the buck in a CNC router spindle that can handle very long router bits (actually endmills) for cutting foam. Probably something in the 3 hp - 5 hp range.
    The cuts aren't that heavy but they need to be deep so the spindle needs to have beefy bearings to handle the loads put on the long bit.
    Also, I would prefer that the spindle be fairly quiet.
    Ideas?
    Thanks folks.
    Feb 2005
    30
    Ideas?
    Dec 2008
    292
    If you are just cutting foam, I would not be that concerned about the bearing being 'stout', not much load on them cutting foam. However, I would be concernded about 'runout' and/or bits flexing under load due to the length.
    Don
    Jul 2009
    690
    I would go with a chinese spindle and a good VFD (people in the forums seem to like Hitachi). Not that I've tried this option myself, but I've read a lot of opinions about it and it seems a reasonable choice if you're in a budget. In fact, I hope to be able to go that way too someday.
    Feb 2005
    30
    Is the runout acceptable and are the bearings pretty good in those Chinese spindles? What seems to be the common failure mode in them- what usually quits working first or needs servicing?
  1. Moving Table Router: MDF contruction but stout
    By bradodarb in forum CNC Wood Router Project Log
    Last Post: 09-04-2012, 07:06 AM
  2. Want to build stout gantry CNC router
    By Jrs_Farm in forum DIY CNC Router Table Machines
    Last Post: 10-23-2009, 08:37 PM
  3. Affordable VMM
    By Leha_Blin in forum Calibration / Measurement
    Last Post: 02-18-2009, 04:25 PM
  4. Affordable Spindle With ATC
    By buckie555 in forum Uncategorised MetalWorking Machines
    Last Post: 03-29-2007, 12:07 AM
  5. affordable wet saw?
    By darth442 in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 07-24-2005, 06:39 PM
